motor swap help
i am buying a 90 INTEGRA ls motor and trans i need to know what mounts i have to get or can i use the ones in my car i have a 89 crx hf and if i need new ones where can i get them i am new to hondas and don;t know to much out them
http://hasport.com/catalog/index.php?cPath=22_24. You need the mount kit thats $ 549. It comes with the shift linkage. Make sure you get the t- breaket of the back of the teggy motor and trans it connects to the rear crossmember mount. Also you need 90-93 non abs axels. 90-93 clutch and throttle cable. 90-91 ecu would be best although not required. Wiring is plug and play. Also if you want ac you need the hasport ac compressor mount. Everything is on the link. The lower radiator hose should work. A 84 or 86 (its been a few yrs) accord upper radiator hose trim to fit works well
