Persistent hesitation problem (already re-wired 02 sensors)
Old Apr 8, 2006 | 01:57 PM
Maxximtl's Avatar
Default Persistent hesitation problem (already re-wired 02 sensors)
ever since I bought my car, it has had a persistent partial throttle hesitation problem. The wiring job that the installer did on the car was really crappy, so I replaced the Vtec wires and both 02 sensor wires with a Rywire sub-harness. I repinned the ECU to ensure everything was perfect. After installing the new harness, my car still has some partial throttle hesitation (it is better than it was before.) This is driving me crazy, and I am not sure what else to check. Here is a run down of what the car is doing.
1. runs perfectly when cold
2. hesitates only at partial throttle (cruising at a steady speed)
3. idles and accelerates fine
Is there a way that I can test the 02 sensors to determine if they are functioning properly? I know one of them has been replaced (previous owner trying to diagnose the same problem.)
Is there ANYTHING else that could cause this problem? I would like to get it fixed.
Old Apr 8, 2006 | 02:46 PM
Voodooboy520's Avatar
Grounds? I hear it helps with slight hesitation.
Old Apr 21, 2006 | 08:46 AM
Black4thgenEF's Avatar
Default Re: (Voodooboy520)
I have the same problem with my B16. Would like to hear an answer.
caspers_hatch
Nov 5, 2005 05:19 PM
gook
30
Sep 29, 2005 10:14 AM
Batoutahell
Apr 25, 2003 06:25 AM
Batoutahell
Apr 25, 2003 05:21 AM
