B18A1 Header fit B16A? 2 o2 sensors? wheres it located?
Old Apr 7, 2006 | 11:02 PM
Jose-aka-Pedro's Avatar
Default B18A1 Header fit B16A? 2 o2 sensors? wheres it located?
Hey guys, I have a question.
Will my old B18A1 Header (Megan racing) Fit and clear my B16A obd0
And does the B16A have two (2) O2 sensors?
And if so, where does the second o2 sensor go? In the header or cat etc..?
Just trying to finish my research before HMO gives me my engine.
Thanks,
Old Apr 8, 2006 | 03:51 AM
Default Re: B18A1 Header fit B16A? 2 o2 sensors? wheres it located? (Jose-aka-Pedro)
Bump
Old Apr 8, 2006 | 11:09 AM
NAem1's Avatar
as far as the header goes: A b18 header will fit on a b16 head because the bolt pattern is the same. The b16s are shorter than b18s when measured from header bolts down to the bottom of the oil pan. The B18 header will work fine on the B16 just sit a little lower under the oil pan and just make sure your not TOO low or else you could have ground clearance problems
Old Apr 9, 2006 | 12:29 PM
Default Re: B18A1 Header fit B16A? 2 o2 sensors? wheres it located? (NAem1)
Ok thanks,
Is this too low? lol
I think I might be,
Ok I stil have a question, where does the second o2 sensor go?
Thanks
Jose
4DRmafia
11
Jan 30, 2007 06:15 PM
b16er
Dec 29, 2006 10:09 PM
handiman15
May 19, 2002 08:47 PM
brian.edge
Mar 25, 2002 05:27 AM
91sifreak
Feb 13, 2002 09:17 PM
