accord engine temp.
i have a 95 accord ex and i think it runs hot all the time the temp is always at the half way point on the temp gauge. how do i make it run cooler???? os is that fine and normal?
If you know some one with an infrared temp gun, you can check the head temp at the upper radiator hose outlet, around 200 degrees is normal when the cooling fans come on and cycle. If that temp at that point is going beyond 210 degrees there might be some other issues.
dderolph
Honda Accord (2013 - 2015)
Mar 5, 2019 09:25 PM
scott1ct
May 16, 2007 05:29 PM
