Automatic ZC Engine better or worse?
Old Apr 7, 2006 | 08:00 PM
Tippyman's Avatar
Default Automatic ZC Engine better or worse?
My gf's dad pointed out to me that my new SOHC ZC engine has a torque converter on it! I don't know why I didn't see it...
So it must be from an automatic car. I know it will work just fine, but i was wondering if my power will suffer? Do they have any differences?
Old Apr 7, 2006 | 08:01 PM
2kTeg's Avatar
Default Re: Automatic ZC Engine better or worse? (Tippyman)
everyone says they are the same but less abused... I am not sure. I had one for awhile. It felt pretty much the same as a 5 speed, but it blew it pretty quick
Old Apr 7, 2006 | 08:37 PM
Voodooboy520's Avatar
Like he said, there perfered because their probably less beat on. I got my DOHC ZC and it was auto, everything under the valvecover is shiney and no baked on oil. To the best of my knowladge, its been well taken care of.
Old Apr 7, 2006 | 09:07 PM
Tippyman's Avatar
Default Re: (Voodooboy520)
I heard they had diff cams or sumthing. So I guess that's just usual heresay BS?
Old Apr 7, 2006 | 10:34 PM
Deo's Avatar
Deo
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I heard they had diff cams or sumthing. So I guess that's just usual heresay BS?</TD></TR></TABLE>
Likely.
Another vote for being the same but less abused. The Intake Manifold is a little differant on the DOHC version atleast, 2 vaccum lines that need to be plugged in the back. If the idle is really weird when you start it up, play around with the vaccum lines.
Your engine still had the converter left on it? Seems weird for some reason, mine only came with the flywheel-ish plate that the converter bolts up to.
Old Apr 8, 2006 | 03:58 AM
CWBETB's Avatar
I would rather have a auto, cant abuse a auto as much as a manual
jeezyskillz
11
Jan 6, 2007 11:38 AM
vti_shifter
Jul 17, 2005 08:31 AM
Corbic
17
Jul 10, 2005 01:36 PM
Creepshow S60
21
Oct 18, 2003 10:42 AM
Arvid
16
May 4, 2003 11:55 AM
