B series mounts
Don't cheap out on mounts, you will regret it when your engine doesn't sit 100% right and it shakes back and forth.
http://www.hasport.com They have the best **** I find.
actually there are cheaper mounts that work perfectly FINE. such as Avid (I own 3 sets)
The reason hasport moutns are more expensive is simple.
It goes wiht the fact you ahve to use ONLY their shift linkages.
The mounts position the engine/axels in such a way as to help PREVENT wheel hop from occuring from launcehes and such. as such also the stock linkages will nto fit. I do not believe it says this on their website, but I know it to be a proven fact as my car has had HAsport/avid/homemade/no-name mounts in it. Hasport mounts are VERY NICE but you dont NEED them. Avids I find work very well, and are able to be used wiht stock shift linkages (=more money saved=cheaper swap=more $$ to upgrade)
so as you see im not dissing them, i am agreeing not to cheap out on mounts, but you also dont need to buy the most expensive kind out there.
Yea I talked with the avid people QUOTE: If its the front JDM EF9 clip with a B16A, yes it will work. If there is
anything else you need please let us know./ENDQUOTE
I had bought an EF9 fornt clip and was worried about it nto fitting.
Yes i SUGGEST HASPORT, they do work, but are 250$ mroe (with shift linkage apprx)
which in alot of cases can be a major deciding factor. I was jsut giving an alternative.
So hasport good. but I also love avid and there customer service !!!
SloCivicHMM
Apr 3, 2003 02:24 PM
