HELP WITH MY DIZZY WIRING FOR MY DPFI TO MPFI ALITTLE LOST !!!!!!!
ok here's my problem i'm doing the swap over from dpfi and i got the whole way to my dizzy and here's the problem the diagram shows 6 wires right ? and my dizzy has 7 ? what do i do with the extra wire ? aslo none of the colors i have match up ... my dizzy has .. ....blue/yellow blue white/blue orange orange/blue white and white ???? and the plug i have has 2 whites .. orange/blue a orange and white blue only 5 wires ?? so can someone tell me what i gotta do here to make this work ??? this dizzy is holding me up i know i have to use the C1 and C2 but do i just wire those into the the plug i have ? if someone could just gimme alittle help here
pics are good !!!!
ok so here's what my dpfi dizzy plug wires are white , white, white/blue,orange,orange/ blue
Here's the plug i have it has orange,white,white,white/blue,orange/blue
Now here's the Si Dizzy colors
white,white,white/blue,orange/blue,orange,blue/yellow and a like sky blue color wire
if you guys can help me out alittle that would be great this is the only thing holding me up
Modified by PrestonCRX at 5:46 PM 4/7/2006
pics are good !!!!
Ok, from your new distributor. Connect the Orange wire and White wire (crank sensor) to two new wires. Those are going to the ECU to connect to B10 and B12 of your new ECU. Connect the orange/blue and white/blue wires (TDC sensor) to the same color wires in your engine harness. Connect the BLUE/GREEN and BLUE/YELLOW (CYL sensor) wires to the old Orange and White wires.
There is one spare white wire on both, it's sort of obvious which wire doesn't pair up with the rest. Connect those white wires together. That's all.
If you need more help, just ask... But there are like, 10 wiring guides online with all the details explained, I'd search
i just did this swap and what you need to do is cut the dpfi dizzy plug off and then match up the colors to the si plug and also wire the wires from c1 and c2. oh and with the two white wires i put connectors on them so if the werent right i could switch them around.
JDMlyfestyle
Oct 16, 2004 07:04 PM
