88 honda crx with a swap d16 dx 00
Old Apr 7, 2006 | 03:43 PM
jdmeksir's Avatar
Default 88 honda crx with a swap d16 dx 00
my friend swap in a 00 civic dx motor in to his 88 crx.
everything works and all but only problem is that it rev high or idles high, its idles or revs up to 5 and up andi cant think of anything that would make it rev that high all the plugs are in and vacums lines only think that was not plug'd in was the water temp sensor switch didnt fit on the 00 block but the sensor is connect none the less but hang...
can anyone give any ideals and please dont care about the upgrade to another motor, he just wants a daily driver
spec of the crx
88 hf
bone stock all around
motor is a 00 honda civic dx
with 88hf tranny
any ideals????
Old Apr 7, 2006 | 09:17 PM
jdmeksir's Avatar
Default Re: 88 honda crx with a swap d16 dx 00 (jdmeksir)
cant anyone answer this question for me???
Old Apr 8, 2006 | 07:01 PM
nacho_man's Avatar
Have you checked the throttle cable? It may be too tight.
Old Apr 9, 2006 | 12:15 PM
jdmeksir's Avatar
Default Re: 88 honda crx with a swap d16 dx 00 (nacho_man)
yea i'd check that
Old Apr 11, 2006 | 05:17 PM
jdmeksir's Avatar
anyone else knows what would the problem be???
Old May 3, 2006 | 01:12 PM
srREXed's Avatar
Your throttle body may be dirty causing it to stick... Do an induction service and clean it out with a toothbrush and tb cleaner... If thats not it then your tps may be fried.
aka throttle position sensor
Old May 3, 2006 | 01:17 PM
crxnj's Avatar
Default Re: 88 honda crx with a swap d16 dx 00 (srREXed)
its revving to 5k revs by itself?? if its not the throttle cable stuck then the only other thing i can think of is a leak at the throttle body ot intake manifold...or some sort of vacuum leak..
your avatar
Armando Pomales
Jun 29, 2019 03:28 PM
Firehaxard
Classic Hondas
Jul 6, 2008 06:47 AM
Jason703Racing
Jan 25, 2006 02:52 PM
iNetForce
Sep 1, 2004 07:58 AM
95GLX
Aug 17, 2004 01:01 AM
