How much can I expect from this setup
Old Apr 5, 2002 | 05:51 AM
metal-x's Avatar
Default How much can I expect from this setup
Skunk2 Cams, skunk2 cam gears, Dc 4-1 header, B&M fuel Preasure regulator, AEM Intake, 10:6 compression, p&p
thank
Old Apr 5, 2002 | 07:57 AM
jujubee's Avatar
Default Re: How much can I expect from this setup (metal-x)
In what engine. B18B(LS) B18C1(GSR) B18c5(ype R) Need more info.
Old Apr 5, 2002 | 08:42 AM
metal-x's Avatar
Default Re: How much can I expect from this setup (jujubee)
sorry its on a B18c
Old Apr 5, 2002 | 09:32 AM
lazyguy's Avatar
u can probly pull down close to 200 depends on what stage skunk 2's ur gonna run with
Old Apr 5, 2002 | 09:45 AM
Type S's Avatar
Default Re: How much can I expect from this setup (b18cURmama)
nope 180-185 with that compression, move up to 11.5:1 compression and you will make 200whp definatelly.
Old Apr 5, 2002 | 11:14 AM
metal-x's Avatar
Default Re: How much can I expect from this setup (Type S)
Im thinking of using the stage 2's, also if I get a thiner head gasket to bump up the compression would that be as good as upgrading to higher compression pistons
negusjuda
Aug 24, 2010 09:37 AM
Got Milk
15
Nov 13, 2005 10:05 AM
JDMSiGuy17
May 16, 2004 08:53 AM
stupidfast
Jul 12, 2003 04:51 PM
gsr squirrel
Dec 6, 2002 07:44 PM
