FORGED PISTONS FOR ZC DOHC
Hi
has any one heard of ITM pistons?
I am about to buy a set of forged ones for the zc dohc. they are said to hold 15-17 psi and are size 0 2 0?
any one know how much bhp i can get from a properly tuned up, turbo'd engine with these pistons ?
Please let me know what you think.
I am open to any suggestions.
Modified by zcdohcturbo at 2:25 PM 4/7/2006
First off, with a properly tuned engine, 15-17 psi can be possible with stock pistons. When not tuned right; detonation kills pistons, high boost kills rods.
Not enough info on pistons,
What c/r do the pistons have with stock ZC 90mm stroke?
What bore size, 75.5mm?
thanks for replying mate
it a set of (ITM) forged pistons with (ITM) rods and they are standard bore size
and yes it will be a properly tuned engine im going with a KMS valve kit and probably skunk 2 cams or crespos.
it is going to get turbocharged, what bhp do you think i can achieve ?
,it a set of (ITM) forged pistons with (ITM) rods and they are standard bore size
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcdohcturbo »</TD></TR><TR><TD CLASS="quote">probably skunk 2 cams or crespos.</TD></TR></TABLE> Since when does Skunk2 Make cams for the DOHC ZC?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> Since when does Skunk2 Make cams for the DOHC ZC?</TD></TR></TABLE>
what is the compression ratio of the new pistions?
thanks for replying mate ,
do not go with kms for the valves!!!! click on my signature 1st, and i was boosting 12 psi on my stock pistons, id say if you only plan on boosting 15-17 psi you should just use your stock pistons for that amount of boost
ZColeon
Jul 25, 2002 04:19 AM
