F/S: 95 GSR Parts & Shell
F/S: 95 GSR Parts & Shell…
You can take it all or take in parts. All items are used, and were removed while in working condition. Large items will have to be picked up, so dibs to the local buyers. I can probably ship small things only, PM me beforehand. If you want something send/leave/text me a message with a RESONABLE OFFER, and I’d be glad to set things up. Will be willing to trade it all for a 90-93 240sx fastback/manual/black interior/running + ca$h. Any questions or comments hit me up @ integr97@hotmail.com or 310/874-8178 THANX!!
Photos can be seen here…GSR Sale Pics
137 a b c) ’95 GSR Shell (Frost White) w/Windshield & Rear Windows
1) Driver Door Wire Harness
2) Pass. Door Wire Harness
3) Power Door Lock Control Unit
4) Pass. Door Pull Handle - SOLD
5) Pass. Door Mirror Cover Panel
6) Pass. Door Inner Handle Trim w/Lock
7) Center Console Frame Bracket
8) Rear Center Console Support Bracket
9) Pass. & Driver Cup Handle Bracket
10) Hood Latch
11) Hood & Engine Bay Rubber Stops
12) Hood Release Cable Lever
13) Steering Column Holder & Pivot
14) Heater Valve Arm w/Cover
15) E-Brake Upper Handle
16) Resonator Chamber Assy. w/Lower Intake Tube Assy.
17) Engine Bay Brake Line Supports
18) Cruise Control Unit Bracket
19) Cruise Control Cable Holder
20) Horn Relay Wire Harness
21) E-Brake Cables - SOLD
22) Driver Door w/Glass & Handle - SOLD
23) Pass. Door w/Glass & Handle
24) Driver Fender w/Stay - SOLD
25) Pass. Fender w/Stay - SOLD
26) Brake Booster
27) Gas & Brake Pedal Assy.
28) Clutch Pedal Assy.
29) Brake Reservoir & Cylinder - SOLD
30) Clutch Reservoir & Cylinder
31) Windshield Wiper Motor Assy.
32) Blower Assy. w/Motor & Fan
33) Evaporator Assy.
34) Driver Headlight - SOLD
35) Pass. Headlight - SOLD
36) Windshield Washer Fluid Bottle
37) Front Sway Bar
37 a) Rear Sway Bar
38) Driver Front Lower Arm Assy.
39) Pass. Front Lower Arm Assy.
40) Driver Trailing Arm w/Hub
41) Pass. Trailing Arm w/Hub
42) Front Main Bumper Support
43) Rear Main Bumper Support
44) Subframe/Crossmember
45) Muffler
46 a) Catalytic Converter w/B Pipe
47) Rear Upper Body Skirt
48) Driver Side Skirt
48 a) Pass. Side Skirt
49 a) Hood
50 a b) Cluster (69492mi.) - SOLD
51) Driver & Pass. Rear ABS Sensor w/Wiring
52) Driver & Pass. Damper Forks
53) Power Steering Pump Feed Hose
54) Hood Support Bar
55) Tow Hooks w/Bolts
56) Driver & Pass. ABS Plugs & Sockets
57) Driver & Pass. Shock & Spring Assy.
58) Subframe/Crossmember Rod
59) Driver & Pass. Upper Arm w/Nuts
60) Driver & Pass. Knuckle, Hub, Rotor & Brake Calipers
61) Driver & Pass. Rear Rotor
62) Parking Brake Lever w/Adjuster
63) Driver & Pass. Shock & Spring Assy.
64) Driver & Pass. Rear Lower Control Arm
65) Driver & Pass. Brake Calipers
66) Heater Box Assy.
67 a) Steering Column Assy. w/Combination Switch & Joint Cover
68) Steering Column & Dash Frame
69) Sun Roof Drain Hoses
70) Fuel Filler Neck w/Gas Cap & Cover
71) Fuel Filler Plate, Cap Holder & Screws
72) Foam Center Console Support
73) Fender Intake Tube w/Bolts
74) Driver & Pass. Side Mirrors
75) Steering Rack w/Tie Rods & Ball Joints
76) Spoiler w/LED & Wiring
77) Driver & Pass. Rear Window Trim Panel
78) Driver & Pass. Door Sill Molding - SOLD
79) Driver & Pass. A Pillar Trim
80) Rear Bumper Upper Beam
81) Driver & Pass. Rear Window Rubber Trim
82) Hatch Support Dampers (pair)
83) Steering Wheel w/Airbag
84 a) Driver & Pass. Tail Lights (98-01) - SOLD
85) Pass Rear Side Trim Panel
86) Rear Trim Panel
87) Front Bumper Upper Stiffener
88) Rear Cargo Cover - SOLD
89) Driver Door Panel w/Carbon Insert, Window Switch & Tweeter
90) Pass. Door Panel w/Carbon Insert, Window Switch & Tweeter
91 a b c) Dashboard w/Wiring
92) Driver & Pass. Side Door Trim Molding
93) Knee Bolster w/Coin Pocket & Fuse Cover - SOLD
94) Gas/Hatch Lever Cover
95) Diver Kick Panel - SOLD
96) Pass. Kick Panel - SOLD
97) Glove Box
98) Steering Column/Ignition Cover - SOLD
99) Pass. Airbag
100) Glove Box Damper Support
101) Rear Windshield Wiper Motor w/Bolts
102) Driver & Pass. Rear Seat Belts
103) Cruise Control Module w/Cover & Bolts
104) Oil Cooler Line
105) ECU w/Cover, Bracket & Bolts
106) Under Hood Fuse/Relay Box
107) ABS Modulator Assy. w/Plugs & Bolts
108) Under Hood ABS/Fuse Relay Box
109) Drivers Engine Compartment Wire Harness
110) Main Interior Wire Harness w/Pass. Under Hood Wiring
111) Hatch/Fuel Lid Opener
112) Hatch Latch & Lock Cylinder w/Bolts
113) Sunroof w/Motor
114) Driver Door Inner Door Handle w/Lock Switch
115) Driver Door Inner Pull Handle
116) Driver Mirror Wire Cover
117) Rear View Mirror w/Cover & Screws
118) Dome Light w/Nuts
119) Map Light w/Screws
120) Fuel Door Release Cable
121) Hatch Release Cable
122) License Plate Bulb Wire Harness
123) SRS Control Unit w/Main Harness & Sensors w/Covers
124) Under Dash Fuse/Relay Box
125) Cruise Control Unit
126) ABS Control Unit
127) Rear Wire Harness
128) Driver Dash Bracket w/Sun Roof & Starter Cut Relays
129) Main Relay Assy.
130) Ignition Wire Harness
131) ABS Sub Wire Harness
132) Heater Sub Harness
133) Radio Antenna w/Antenna Wire
134) Roof Wire Harness
135) Hatch Wire Harness
136 a) Front Bumper w/Turn Signals
10) Hood Latch
26) Brake Booster
37) Front Sway Bar
37 a) Rear Sway Bar
45) Muffler
49 a) Hood
86) Rear Trim Panel
97) Glove Box
99) Pass. Airbag
