Circuit Worx Integra Hubs
Old Apr 7, 2006 | 09:10 AM
xrdriver's Avatar
Default Circuit Worx Integra Hubs
Hello!
I picked up some used Circuit Worx axles and hubs recently but I completely missed the fact that the hubs were for a Civic spindle. I have an EG hatch but I have 94-01 Integra spindles with the Fastbrakes 11" rotors so I need the Integra hubs.
Does anyone know where I can get some of their Integra hubs cheaper than the $159 per hub from Circuit Worx?
Old Apr 8, 2006 | 09:26 PM
xrdriver's Avatar
Default Re: Circuit Worx Integra Hubs (xrdriver)
anyone?
Old Apr 9, 2006 | 07:16 AM
XXXRacing's Avatar
Might want to check out James at Mazworx.com he used to be a dealer, might be able to save you a few bucks.
Old Apr 9, 2006 | 07:32 AM
SpeedDreamz.com's Avatar
Default Re: Circuit Worx Integra Hubs (XXXRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XXXRacing &raquo;</TD></TR><TR><TD CLASS="quote">Might want to check out James at Mazworx.com he used to be a dealer, might be able to save you a few bucks.</TD></TR></TABLE>
I think he also had a couple of axle setups he wanted to sell.
Old Apr 9, 2006 | 07:34 AM
seen4ever's Avatar
EG & Integra hubs are the same, hence why when you do a b-series swap, you don't have to change hubs.
although if you have the big boy axles, they might have a 36mm spine rather than the stock 32mm spine, which would mean you need the circuit work hubs to fit the bigger spines. aka, is the axle nut 32mm or 36mm?
Old Apr 9, 2006 | 08:09 AM
xrdriver's Avatar
Default Re: Circuit Worx Integra Hubs (seen4ever)
The Circuit Worx axles use a 36mm bolt. The problem is not the spline it is the hub where the rotor sits. The Integra rotor has a much bigger hat. Here is a pic of the stock Integra hubs and CW Civic hubs:
Old Apr 9, 2006 | 09:12 AM
tommyten's Avatar
they have 2 different hubs (circutworx), one for the integra & one for a civic.
The only diffrence being that the civic one is smaller since the integra uses a bigger wheel bearing than the civic does. But they both still fit the same axle
Fate
Jan 4, 2006 05:02 PM
I_eat_Rice
Sep 1, 2005 09:03 AM
B2FiNiTY
Mar 11, 2004 10:18 AM
Propulsion
Aug 4, 2003 06:07 PM
civichopeful
Oct 13, 2002 03:42 AM
