k24 stock bore and cmpression?
Old Apr 7, 2006 | 08:35 AM
89a6T's Avatar
Default k24 stock bore and cmpression?
trying to get these specs. also oem piston specs for the higher compression k24s.
Old Apr 9, 2006 | 01:01 PM
msantas's Avatar
Default Re: k24 stock bore and cmpression? (89a6T)
the bore is 87 mm i believe. the compression varies since there are different variations of the k24. the k24a1 (crv) has a 9.6:1 compression, the k24a2 (tsx) has a 10.5:1 compression, and the k24a4 (accords and elements) has a 9.7:1 compression.
Old Apr 19, 2006 | 09:48 AM
kevinoneill's Avatar
Default Re: k24 stock bore and cmpression? (msantas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msantas &raquo;</TD></TR><TR><TD CLASS="quote">the bore is 87 mm i believe. the compression varies since there are different variations of the k24. the k24a1 (crv) has a 9.6:1 compression, the k24a2 (tsx) has a 10.5:1 compression, and the k24a4 (accords and elements) has a 9.7:1 compression.</TD></TR></TABLE>
Correct 87mm bore, 99mm stroke. The rest is good too.
Old Apr 19, 2006 | 12:56 PM
89a6T's Avatar
Default Re: k24 stock bore and cmpression? (kevinoneill)
piston compression height? i need 1.181 to fit my block. thanx for the info.
yrpin5th
51
Dec 29, 2008 05:36 PM
dc4teg95
Nov 6, 2007 04:18 AM
1.8T_EG
Jul 6, 2004 08:27 AM
YOSOLO CRX
13
Nov 13, 2003 08:53 PM
ITR.00-1282
Mar 30, 2003 09:04 AM
