h22 install help
Old Apr 7, 2006 | 07:43 AM
3a_eg_hatch's Avatar
Default h22 install help
has anyone installed a h22 in a eg. if so how fucked up was it to do the shiftlinkage, and was there any pounding in the engine bay to make it fit
Old Apr 7, 2006 | 07:45 AM
IHateJDM's Avatar
Default Re: h22 install help (3a_eg_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3a_eg_hatch &raquo;</TD></TR><TR><TD CLASS="quote">has anyone installed a h22 in a eg. if so how fucked up was it to do the shiftlinkage, and was there any pounding in the engine bay to make it fit
my engine dropped right into place easily, but if you have a shitty mount kit, it might be harder. shift cables were easy too, as long as you have the right tools to cut the hole. My whole swap went far smoother than I was expecting. Good luck.
Old Apr 7, 2006 | 07:47 AM
Default Re: h22 install help (IHateJDM)
how did u know how big to cut the hole
Old Apr 7, 2006 | 07:53 AM
IHateJDM's Avatar
I used an aftermarket box that the shifter mounted into, so I cut a hole the size of that box. If I were using the stock braket though, I would bolt the braket in place based on the interior of the car, then cut a hole about 3" wide, 2" long a few inches in front of the bracket. It doesn't have to be perfect, just make sure the cables will reach before you start cutting (don't start on the shifter until the motor is bolted in the car).
Old Apr 7, 2006 | 02:04 PM
cool
VTECengaged
Dec 30, 2007 07:34 AM
JDMhatch3190
Oct 9, 2007 06:21 AM
3a_eg_hatch
Apr 6, 2006 09:03 AM
VTECR021
Mar 21, 2005 08:50 AM
