Valvespring Stiffness
Old Apr 7, 2006 | 07:24 AM
Matty.'s Avatar
Default Valvespring Stiffness
I see people say that certain valvesprings are too stiff for their applications, just wondering what this criteria is based on.
How do people know how stiff a valvespring is unless they have spring pressure testing machines/ tools and what is the consequences of running too stiff a valvetrain?
Old Apr 7, 2006 | 09:39 PM
EnzoSpeed's Avatar
Default Re: Valvespring Stiffness (gumtape_deathmatch)
All that comes to mind is:
1. Stiffer spring = greater Cam resistance = HP loss
2. Stiffer spring = greater Cam/Rocker pad wear
But I've never heard people gripe about having too stiff a spring. The benefits (no valve float) still outweigh the costs (slight power loss).
Old Apr 10, 2006 | 06:45 AM
Matty.'s Avatar
Default Re: Valvespring Stiffness (EnzoSpeed)
Thanks for the info. That pretty much confirm what I was thinking, just that I was afraid that too stiff a spring may stretch a valve or even pull it into the head. On Hondas this sounds possible since the valve are steel and the heads are aluminum.
Old Apr 10, 2006 | 12:57 PM
EnzoSpeed's Avatar
But the valve seats are steel. The valves never actually contact any aluminum.
Old Apr 11, 2006 | 09:26 PM
IndySporty's Avatar
too much spring will cause the cams to eat into the head eventually. Just like the old 87 CRX Si engine. They took the EW3 carbuerated engine and stuck a dual valve spring higher lift cam into it and fuel injected it and the cams always ate into the heads after 100k.
Old Apr 11, 2006 | 10:55 PM
EnzoSpeed's Avatar
Default Re: (IndySporty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty &raquo;</TD></TR><TR><TD CLASS="quote">too much will cause the cams to eat into the head </TD></TR></TABLE>
What does that mean?
Old Apr 12, 2006 | 07:40 AM
Matty.'s Avatar
Default Re: (EnzoSpeed)
I imagine what you are saying is the journals or cam cap went to an extreme out of round condition....? This is the only place the cams contact the head. Otherwise its all rocker arms.
thehatchninja
14
Sep 2, 2005 08:57 PM
importlegions
Jul 15, 2004 08:53 PM
Screamer
Dec 17, 2003 04:41 PM
ic108
Feb 14, 2002 04:49 PM
