wheel clearence issue...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo »</TD></TR><TR><TD CLASS="quote">should hit easily stock wheel is 15 w. 45 offset</TD></TR></TABLE>
Dont spread bad information. The stock wheel is an INCH narrower than the one he specifies and width is directly related to the offset, which is +50 at 6" wide for the OEM wheels NOT +45.
I'm sure you'll be ok with that width and offset, but heres another tool to help too http://www.1010tires.com/WheelOffsetCalculator.asp
Modified by KOALA YUMMIES at 12:09 PM 4/7/2006
Dont spread bad information. The stock wheel is an INCH narrower than the one he specifies and width is directly related to the offset, which is +50 at 6" wide for the OEM wheels NOT +45. I'm sure you'll be ok with that width and offset, but heres another tool to help too http://www.1010tires.com/WheelOffsetCalculator.asp
Alexander
Mar 25, 2005 02:40 PM
