dc5 oem b-pipe plus tannabe racing medallion axleback????????????
as topic sed. i have a tanabe racing full exhaust for my 02 dc5. My b-pipe is all fucked up, dented real bad due to a rear accident that cause my exhaust to push up towards the cat and it is now bent a lil which cause the exhaust to hang reall low. i scrape ever bump i come by. my question is will a dc5 oem b-pipe bolt right up to my axleback? plz help because my shitty *** b-pipe is really annoyin and f-ed up. i'm just tyrin to go the cheapest route inestead of buyin a whole new catback. thanks
the reason i'm doin it becuz i'm not really tryin to soop my car up and money is something i dont' have much at the moment. I found a guy who is sellin a oem b-pipe VERY CLEAN for only 40 bucks. so i was just seein if i can just erplace the axle back on the b-bpipe. I Know i can go to a muffler shop, i've gone through those alot due to fact i had a eg, and in process, i'm workin a crx and del sol. So i just curious if this would work that way i woudln't have to actually spend that much money on my rsx. i just want my rsx as a daily driven car while on the weekends, i'll take out my other toys. you feel me? but anyways thanks for the tip.
Don't know if you had a chance to see the OEM mid pipe but the flange is different from the Tanabe flange. Plus you'll be giving up a lot of pipe diameter (and some HP gain) for a big increase in noise from the axle back. If you're really on a budget, have a muffler shop cut out the bent part of the Tanabe mid pipe and weld in new section. For what it's worth, I had a Tanabe Hyper on my car and it dyno'd .5 WHP less than my friends base auto with a Tanabe Racing. The mid pipes on both are the same, the gains are from the overall larger pipe diameters, not the muffler section in this case.
SpoonyDC5
Jan 8, 2013 03:43 PM
honisoto
Oct 15, 2008 10:00 PM
MestizoRacer310
Sep 9, 2005 06:16 PM
