Tips for taking off stuck oil filter
Screwdriver will work, but like said... LAST resort... There is an oil filter remover called the claw, which is adjustable, it has 3 prongs on it that clamp around the filter and tighten as you try to loosen the filter... I forget where I got it though... gotta think...
Reefer_Bob.
Reefer_Bob.
latex or Mechanix gloves, grip hard and turn
if that doesnt work.. you can try using a piece of sandpaper to grip the filter and then turn it.. if htat still doesnt work try using an oil filter wrench.. there are a few kinds.. one where the tips are semi circles and grip on the filter, theres the kind that attach to a 3/8" ratchet.. as you turn it to loosen the tips close and grip ... theres the normal oil filter wrenches, if all else fails.. jab a screwdriver thru it and turn...
My last oil change I used all the normal methods, then I used the screwdriver and the filter casing ripped. I ended up putting 5 holes in it before it was loose enough to turn by hand(punch, turn about 1/32 of a turn and the hole was too deformed to use, repeat).
I'll never go to a quick lube place again.
lol yes the leather belt!!
As much as I hated to punch a screwdriver through my oil filter, I had to do it today. The weird thing is that I only screwed my filter on hand tight(because ever since I switched filter brands, my filter wrench doens't fit anymore) and even though I tightened the filter hand tight, for some reason my hand wasn't able to get it out. So it does happen and the screwdriver was my last resort, because I couldn't drive my car to get a oil filter wrench that fit. HTH
make sure when replacing it to put a little oil around the rubber seal on the end of the filter, this will also help in getting it off again, as it stops the rubber from sticking/melting to the hot engine
ahhh the screwdriver death stab! I know it well. Last time it was a hot Mobil1 bath
I took pics of the filter...need to get them up.
You can try the cap thingys (I never get them to fit) or the strap things or the huge *** Channel Lock pliers (a personal favorite).....or you can get this, a gift from Heaven....
http://buy.snapon.com
EDIT\\\okay no doubt the above link is DOA. So, go to snap-on and get the adjustable oil filter wrench. As you tighten, it tightens against the filter. It wouldn't have worked on the last filter I had to stab (I ended up bending two screwdrivers on this beauty) but it should do the trick for other ones....
[Modified by Tweakmeister, 1:25 AM 9/18/2002]
I always use a piece of coarse sandpaper. I don't even try any other method first, I just get the sandpaper and go at it.
damn I sure wish I knew about the sandpaper method before I stabbed my filter. Has anyone ever done or heard of anyone doing any damage to the engine block using the screwdriver stab method?
I use the claw. Works without fail, unless i use the smaller Honda filters from the 'K-series engines or the HAMP filters.
I'm trying to find a smaller claw.
how tight are you guys putting your filters on? i put mine on hand tight, and get it off with a hand. it probably helps i use the filters with a textured grip, but filters dont need to be so tight.
Punch a screw driver into it and unscrew.
