gsr or type r
quick question for all, if you were to take a gsr and build it with type r internals, parts, how much difference in power would there be between that set up and a type r motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20o2o4civic »</TD></TR><TR><TD CLASS="quote">quick question for all, if you were to take a gsr and build it with type r internals, parts, how much difference in power would there be between that set up and a type r motor</TD></TR></TABLE>
nobody will really know it until they actually put it on dyno to check it out
but shouldnt be too much of differance i guess..
only differance would be the compression ratio.. 10.6:1 Vs 10.0:1
i dont know what the .6 CR will do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">
i dont know what the .6 CR will do </TD></TR></TABLE>
Actually the GSR head has smaller combustion chambers so it bumps the compression a bit higher to around 10.8:1.
So you would gain a moderate amount of compression. If built right, it could be a fun motor.
use ctr pistons in a gsr block and you'll have 11.5-1 compression.. perfect for big cams
just make sure you DO NOT mill the head... other wise you will have clearance issues
