FS: GSR Parts, gearboxes, etc, etc
Old Apr 6, 2006 | 09:54 PM
Driven's Avatar
Default FS: GSR Parts, gearboxes, etc, etc
Mind you, I'm creating an interest list for the engine parts, as I haven't received all the parts back from the builder...
Interior Pieces:
- '94 GSR Interior door panels (black). Comes with window switches. $40/each
- '94 Gauge cluster. Comes with gauge surround. $30obo
Engine Parts (all have roughly 115,000miles, removed to freshen engine up, not due to engine failure or excessive/abnormal wear):
- '94 GSR Camshafts (intake and exhaust). $100 or trade for non-aem cam gears.
- P72 Pistons. standard size, with rings. $15/each, or $50 for all four.
- P72 Valves. $40 for all.
- P72 valve springs. $40 for all.
- P72 Rods... $60
Gearbox:
- B16 cable flywheel, pressure plate, and clutch. $50obo
- J1 cable transmission. Works perfect. Never slammed into gears. Drag raced less than 15 times. Mainly used for road racing, where double clutching and heel-toe was used to select next gears. This was used in perfect working condition right up to January when i removed it. $400.
- hydro GSR casing. Make an offer
- YS1 gearing. make an offer. (yes, i swapped the hydro gears into a YS1 casing).
- Bseries "JDM" 2.5" collector header. abused. $20
Exterior:
- ED CRX headlamps. $40 for both.
- '90-91 CRX Front bumper. Yellow. $20. indentation near where hood meets. It's better than a black bumper though (unless you don't have a yellow car).
Combining other for sale ads i have:
Autometer Gauge, Ultra-Lite, 160 MPH, Mechanical Speedometer, 3 3/8 in.
Part # ATM-4493
Currently shows 10096 on the odometer.
has a trip and when ran with a B16A S1 cable gearbox, is accurate within 10mph.
The factory CRX speedo cable plugs right into the back of the gauge with no modification.
I used it right until i switched to an electric VSS. I custom fabbed up a gauge cluster.
as shown here:
Closer pic:
$60 obo.
_______________________________________
P30 Pistons and Rings
Brand spanking new.
Bought the pistons from JHPUSA.com shipped for $209.99 in December 2005. They list them for $199.
The rings were purchased from Acuraautomotiveparts.com shipped for $105.88 in December as well. They listed them at $26.47/ea
$280 shipped.
$250 pick up.
They are oversized pistons.
_________________________________________
'91 CRX Si L3 Gearbox. Worked fine without grinds as far as I know, taken out of a parts car. $100.
Eibach Front/Rear Extended Top Hats
Require Ground Control coilovers.
$90/pair
Custom made Front Extended Top Hats
Do NOT require GCs. These are OEM top hats that have been modified to extend shock travel 1.25".
$50/pair.
chrome aftermarket Muffler, unknown brand. Cut off my maxima. used for 2 days. $20.
CRX Rear Strut tower brace. $10.
GSR and CRX Starters. They both work. $10/each.
OBD1 (GSR) Distributor. Works fine. $100
Various CRX knuckles. $5/each (good for seeing how everything comes apart).
CRX yellow mudflaps. $10/set (front and rear)
'94 Civic DX Tape/Radio deck. worked alright.
$10.
Unknown original Honda tape/deck player (it came in my Hf).
$5.
euro amber colored corner markers for CRX.
$5/pair
clear corner markers for Civic
$5/pair
Non Honda
Lowering Springs for a Toyota Solara. 99-04?
$50
Stock springs for a Nissan Maxima. '00-'04
$50
Di Di Mau
May 23, 2009 12:08 PM
jdmekcivic2eg
Dec 11, 2003 05:13 AM
Max GSR
May 23, 2002 12:20 PM
