gt35r turbo is too big for ls setup? should i get a smaller turbo?
hey guys, i just baught a gt35r ball bearing turbo and didnt reallized how big this thing was.
compressor: 56trim .70 a/r
turbine: 84 trim .82 a/r
i baught it for my ls vtec turbo set up:
ls block:
wisco piston
eagle rod
complete balance bottom block
gsr head:
stage 2 port/polish
gsr cams
bronze valve guide
crower dual valve spring and titanium retainer
rev stainless steel valve(3 angle valve job)
venom manifold
skunk2 adjustable cam gear
need some comment on the turbo. is it too big for the set up, should i use a smaller turbo? any one experience on this turbo before?
picture here
http://viewmorepics.myspace.co...cc3ed
ls block:
wisco piston
eagle rod
gsr head:
stage 2 port/polish
gsr cams
bronze valve guide
venom manifold
picture here
yeah full boost by around 5300maybe on low boost. the turbo is good to 30+psi but your only gonna use 15 of it, i think a gt30r would be better suited for your setup, unless your leaving room for the future
the .63 a/s is alittle small for me...im want to make between 400-500 whp...for the turbo setup:
equal length manifold
3" downpipe
maeby turbonetics evolution wastegate or tial 38mm wastegate
hks bov
2.5 mandrel bent charge piping
big fmic 12x3x34
planning to boost 15lb when race and maby 5-8lb for daily driving
do you think the dual stage boost control good for this setup?
3" downpipe
hks bov
big fmic 12x3x34
that too big for me beside to expensive lol. i'll be boostiing around 15psi so i dont think i need that much...my most ocncern is the turbo lag.... i want know for sure when it reach full boost for the ball bearing..want to know from those who own one..
For your power goals I would have got a gt30r... Spool up would have been better and U still could get up too 450-500 HP.. It's a much better for a street setup like yours..
Look at this LS gt30r dyno:
http://forums.evans-tuning.com...=3084
Still got 450 hp on high boost and had also had alot of usable power. MAKING the a car fun to drive and fast..
As far as the 44 being too big for you, you'll want to have the bigger wastegate...
you're using a large turbo on low boost.... and that means that you're going to be by passing alot of the exhast gases on the top end and you're going to have some serious boost creeping issues if you run the 38mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3k9civic »</TD></TR><TR><TD CLASS="quote">the .63 a/s is alittle small for me...im want to make between 400-500 whp...for the turbo setup:
3" downpipe
hks bov
big fmic 12x3x34
do you think the dual stage boost control good for this setup? </TD></TR></TABLE>
we made 573 on race gas, and 470 on pump........on a B16!!!!!!!!! with a .63AR, vtec set at 4500, the car shredded BFG drag radials non stop
the 30R would have probably better suit your spool likings and power goals
3" downpipe
hks bov
big fmic 12x3x34
You can buy a $1300 ball bearing turbo that may be too big for your setup, but spending $100 more on a Tial 44mm over a Tial 35/38mm is overkill?
You may want to reevaluate your plans for the car then if things like a good wastegate aren't as important as how big your turbo is.
Just my opinion.
Just my opinion.
hey go to atp turbo and look up the gt25r/40. Good for 450 horse and its ball bearing i have one in my car and itsfucking awesome. It is kinda big but spolls up super quick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">shoulda went with the .63 AR on the exhuast</TD></TR></TABLE>
yupper
yupper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MindEracer »</TD></TR><TR><TD CLASS="quote">For your power goals I would have got a gt30r... Spool up would have been better and U still could get up too 450-500 HP.. It's a much better for a street setup like yours..
I read on a thread in Evans-Tuning that there is no difference between the spool of a 30R to a 35R..... and the 35R might actually spool slightly faster. He would know since he swapped the 35R for the 30R on his race car.
</TD></TR></TABLE>I read on a thread in Evans-Tuning that there is no difference between the spool of a 30R to a 35R..... and the 35R might actually spool slightly faster. He would know since he swapped the 35R for the 30R on his race car.
