accord h22 swap concerns
Old Apr 6, 2006 | 06:40 PM
vtec-adykt's Avatar
Default accord h22 swap concerns
I am having trouble locating a jdm map sensor to work with my buddys h22a. Its going into a 94 lx. Can i rig something else up? like a crx map sensor?
Also, i cant find a used prelude evap canister anywhere. Will the accord one work?
Old Apr 6, 2006 | 07:41 PM
i_kick_turtles's Avatar
Default Re: accord h22 swap concerns (vtec-adykt)
Just use a sensor from a usdm h22. It doesn't have to be"JDM". They're the same sensor.
Old Apr 6, 2006 | 07:48 PM
momstaxi's Avatar
you can use any map sensor off any honda, as long as its mounted on the throttle body...i believe alot of crx's use firewall mounted map sensors...
Old Apr 7, 2006 | 05:51 AM
vtec-adykt's Avatar
Default Re: accord h22 swap concerns (momstaxi)
yes, i can use any map sensor on the usdm models. My h22a throttle body doesn't have the map on the throttle body. I believe it mounts on the firewall.
Old Apr 7, 2006 | 08:28 AM
SpeedFreak77's Avatar
How do you currently have it set-up?
What I did was pull the map sensor off my Accord motor and mounted it to the firewall, then extended the wiring a bit and ran the vacuum line to the throttle body.
Old Apr 7, 2006 | 01:16 PM
vtec-adykt's Avatar
Default Re: accord h22 swap concerns (SpeedFreak77)
what about the evap canister? Can i just use the accord one and run a "T" from one of the two vacuum lines?
Old Apr 8, 2006 | 01:53 AM
Yeah you use the Accord evap canister and just run the vacuum line for the map sensor to the nipple on the top of the throttle body.
purplenurple1
Oct 27, 2010 09:50 PM
h22a_93accord
Apr 12, 2008 10:27 AM
SpeedFreak77
Jan 20, 2005 12:57 PM
ricekiller1
Apr 15, 2004 05:58 AM
ricekiller1
Apr 14, 2004 05:52 PM
