Suspension & Brakes Theory, alignment, spring rates....
GC's and Koni's on DA
Old Apr 6, 2006 | 06:39 PM
hangac1093's Avatar
Default GC's and Koni's on DA
I am getting ready to lower my integra and I am looking into Ground Controls and Koni yellows. I was wondering if I need to but upper strut mounts or will the stock ones work. Thanks for any help?
Modified by hangac1093 at 5:21 AM 4/7/2006
Old Apr 7, 2006 | 04:26 AM
CRX Lee's Avatar
Default Re: GC's and Koni's on DA (hangac1093)
Stock ones are fine unless you are going to really lower it a lot (not advised to go too far as you trade hanfdling and ride for basically looks only) at which point then can be helpful. Not mandatory though.
Old Apr 7, 2006 | 01:46 PM
hangac1093's Avatar
thanks man. Also is there any kind of bump stop with that set up?
Old Apr 7, 2006 | 01:51 PM
94eg!'s Avatar
#1 Super Guy
Loved
You will have to re-use your stock bump stops. You usually just cut them in half (depending on how low you go). Never use less than 1 inch of bump stop...
Old Apr 7, 2006 | 07:09 PM
hangac1093's Avatar
Default Re: GC's and Koni's on DA (94eg!)
This is kind of a stupid question...but I have never owned a lowered car before. How will the Koni's and the GC's mount in my da? I understand how a complete coilover like Omnis bolt up because they are all complete with top hats that just bolt right up. Correct me if I'm wrong, the Koni will go inside of the coilover, then the coilover will mount to lower control arm.(here where Im confused) know the stock top hat stays in the car and the Koni slides up into it and you put the nut on it and tighten? I would really appreciate any input. Thanks.
Old Apr 7, 2006 | 07:29 PM
AutoXer's Avatar
They all install the same way.
https://honda-tech.com/zerothread?id=1106020
Just place the coilover on the shock instead of the stock spring and mount.
Old Apr 8, 2006 | 09:07 AM
hangac1093's Avatar
Default Re: GC's and Koni's on DA (AutoXer)
Thanks man the Link was a big help.
43!
Suspension & Brakes
Jul 24, 2015 11:18 AM
hawaiieg6
Suspension & Brakes
Aug 11, 2009 05:47 PM
BoostKiller
Suspension & Brakes
Feb 28, 2009 04:24 AM
krazyteg
Suspension & Brakes
45
Jun 6, 2007 04:11 AM
beedoublejay
Oct 9, 2004 11:29 AM
