HELP! 2 bar GM map sensor, any good??? searched and 3 bar came up.
Old Apr 6, 2006 | 05:13 PM
92gsrteg's Avatar
Default HELP! 2 bar GM map sensor, any good??? searched and 3 bar came up.
hey everyone, theres a GM 2 bar map sensor on ebay for sale with the pigtail, i wanna know if i shoudl bid on it and how much its worth. I searched but only the GM 3 bar map sensor kept poppin up. will the 2 bar work on my crome pro tuned p28ecu, also what psi is it good up to?? LMK thanks guys. just wanna know if i should bid on it or just get the 3 bar for some good reasons
Old Apr 6, 2006 | 05:26 PM
I Have an STD's Avatar
wrenchin'
Default Re: HELP! 2 bar GM map sensor, any good??? searched and 3 bar came up. (92gsrteg)
just buy the motorola 2.5bar. a 2bar sensor is only a half bar more than a stock honda sensor. the motorola is cheap too, and the tuners ive talked to say they like the motorola more than the GM
Old Apr 6, 2006 | 05:28 PM
leed's Avatar
Ive used the GM 2bar on CROME before. It was able to see up to 14.6psi. CROME includes the setup for this MAP sensor when using BoostTools.
If you plan on running more that 14ish psi, you might look into the Motorola 2.5bar. Much less expensive and a high quality part. CROME supports the Motorla MAP as well.
Good luck
Old Apr 6, 2006 | 05:53 PM
N20civicB18's Avatar
Default Re: HELP! 2 bar GM map sensor, any good??? searched and 3 bar came up. (leed)
Stock is 1.75 bar so your not gaining much
Old Apr 7, 2006 | 06:18 AM
200cs's Avatar
Default Re: HELP! 2 bar GM map sensor, any good??? searched and 3 bar came up. (I Have an STD)
where could one find the Motorola Unit? I want to replace my stock one
Thanks in advance
Old Apr 8, 2006 | 02:54 PM
92gsrteg's Avatar
thanks everyone, greatly appreciate the help, ya i think i'll try to look for a motorola 2.5 then, if anyone knows someone sellin one on here, LMK, thanks again.
Hybrid
Jun 27, 2003 05:15 PM
CiViC SiR
Jun 25, 2003 04:56 PM
89civic1.8T
Jul 12, 2002 11:22 AM
0-60n4
May 23, 2002 03:58 PM
0-60n4
May 22, 2002 07:39 AM
