Steering Knuckle
Old Apr 6, 2006 | 02:16 PM
Yellowone's Avatar
Default Steering Knuckle
Ok guys i got a ? everytime i hit a bump or something i would hear some clanking from the front of the car so i decided to take off my wheels and inspect my front suspension. the steering knuckle seems to be a little loose from the upper control arm. what would i need to do to make it better . btw i have coilovers and 17's if that helps
Old Apr 6, 2006 | 03:24 PM
schardbody's Avatar
what do you mean, are you saying the upper ball joint has play??? all the manual steering honda's i have driven make clunking noises from the rack and pinion after a while, its not a big problem. if its real bad get it checked out.
Old Apr 6, 2006 | 03:50 PM
Yellowone's Avatar
Default Re: (schardbody)
what i mean is that when i jack up the car and take the wheel off i can move the steering knuckle up and down i checked out my buddies civic of the same gen and it doesnt move
Old Apr 6, 2006 | 04:01 PM
schardbody's Avatar
oh, thats because of the coilover sleeves, they all do that.
Old Apr 6, 2006 | 04:31 PM
michsuxkg's Avatar
Default Re: Steering Knuckle (YellowOne)
t
Old Apr 6, 2006 | 05:14 PM
Yellowone's Avatar
i dont mean move the whole thing up and down i just saying that i can move it cuz i think the castle nut that holds the steering knuckle and upper control arm is loose
Old Apr 6, 2006 | 05:30 PM
schardbody's Avatar
oh, the upper ball joint nut, tighten it up, if its tight then the ball joint is bad.
Assassinxiv
Suspension & Brakes
May 13, 2013 02:45 PM
Annihilator
Feb 9, 2011 12:03 AM
hondazccivic
19
Oct 16, 2008 08:20 PM
LSV_REX
Mar 31, 2006 12:36 PM
