PARKING LIGHT PROBLEMS
Old Apr 6, 2006 | 12:29 PM
egredspools's Avatar
Default PARKING LIGHT PROBLEMS
my parking lights are not working but my brake lights work and head lights work and the turn signals the 10 amp fuse blows every time i turn the lights on then i changed the bulbs on the turn signals once and it worked a couple times and it started burning the fuses.......i think there is a short but i dont know could the sockets be bad ????confused holla at your fellow honda man if u got input???
Old Apr 6, 2006 | 12:45 PM
CALIdelsolSIR's Avatar
Default Re: PARKING LIGHT PROBLEMS (egredspools)
if this is a must (like need today so you can drive)
you can always cut/splice the brake underneathe the brake pedal and cut/splice your running lights and your lights will stay on as long as they are connected. When you park and turn off your car, you will need to undo the above.
Old Apr 7, 2006 | 05:54 AM
Default Re: PARKING LIGHT PROBLEMS (CALIdelsolSIR)
anybody know wat i can to d solve this issue
Old Apr 8, 2006 | 04:45 AM
anybody have any more input
Old Apr 8, 2006 | 04:46 AM
Old Apr 8, 2006 | 05:10 AM
lhd dc2's Avatar
Did you install a cd player recently? or did any electrical wiring? You have a hot power wire grounding down to something metal or touching another wire. You should check for any loose wires behind the cd player. Tape up all the exposed wires. Just check over everything if you recently messed with any electrical wires.
This happened to me a couple years back in my EF. I installed a cd player and didnt tape up the power wires good and it grounded down to the chassis and melt my wires from the cd player up to my signals. I had to rewire 2 wires. I was stumped also, wondering why every damn fuse had blown everytime I turn my lights on. And that was the problem.
Good luck.
b16avtecinteg
Lighting
Jan 30, 2008 11:49 PM
mzaner
Sep 11, 2006 05:49 PM
crexer
19
Jul 18, 2003 02:51 PM
Scary1109
Jul 20, 2002 09:36 AM
