AIRCRAFT Paint Remover
Old Apr 6, 2006 | 11:54 AM
epi79's Avatar
Default AIRCRAFT Paint Remover
Any other Paint remover works best outthere ?
I want to polish my wheel , where did u guys buy aircraft paint remover ?
online store ? store ?
is it the best paint remover outthere ?
should i buy a gallon liquid or spray paint works best?
Thank you guys !!!!
Old Apr 6, 2006 | 12:09 PM
crxforum's Avatar
Default Re: AIRCRAFT Paint Remover (epi79)
Well In my experience the gell works the best but you have to kill about 3 brushes on a set of rims pushing it around and getting it all over the rim. The spray is easier to distribute, but seems to be of poorer stripping quality. You can get most of this stuff at any body shop supply store like Sherwin Williams and others. If you cant find those anywhere Im sure that Pep Boys or another place like TSC will have something for you to get there.
Remember that not all of the strippers are the same. Some will eat away at rubber so read the back carefully to know exactly what you are getting. Just to be safe I highly suggest getting the tires off the rims in the beginning.
For a thread on how to polish you wheels when you have then stripped down check out 2poin2's thread here:
https://honda-tech.com/zerothread?id=1259115
They will turn out like this if you follow them correctly.
CRX Forum
Old Apr 6, 2006 | 12:17 PM
Lookinaround's Avatar
New User
Default Re: AIRCRAFT Paint Remover (crxforum)
I strip the valve covers i paint with the Air Craft remover Spray can.
I've used bother the Can and the straight bottled liquid, and I've found that for some reason the rattle can works better.
I buy my stuff at walmart or autozone...advanced doesnt carry the stuff in my town.
Old Apr 6, 2006 | 12:28 PM
eg6r0ll
Guest
Posts: n/a
Default Re: AIRCRAFT Paint Remover (Lookinaround)
Very nice.
Old Apr 6, 2006 | 12:31 PM
DUFFM4N's Avatar
Default Re: AIRCRAFT Paint Remover (eg6r0ll)
aircraft remover in a aresol spray can is perfect for polishing wheels in my opinion
here's a shitty pic of my car from a while back, but i did the lip on these MR5s with aircraft remover/sand paper/mothers mag wheel polish
Old Apr 12, 2006 | 07:26 PM
DFW's Avatar
DFW
Default Re: AIRCRAFT Paint Remover (DUFFM4N)
How did you cover your tires from the spray?
Old Apr 12, 2006 | 07:36 PM
VRD^sam's Avatar
Default Re: AIRCRAFT Paint Remover (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">How did you cover your tires from the spray?</TD></TR></TABLE>
tape the tires y0
Old Apr 12, 2006 | 07:39 PM
DFW's Avatar
DFW
Default Re: AIRCRAFT Paint Remover (joe moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe moua &raquo;</TD></TR><TR><TD CLASS="quote">tape the tires y0</TD></TR></TABLE>
so i can get melted tape on my tires?
Old Apr 12, 2006 | 07:40 PM
sandiegan's Avatar
i just used Jasco (home depot) this weekend, the kind you put on with a brush. was stripping a front lip. omg that **** burns if you get it on your skin by accident lol. i really hate working with it, had to do about three coats, a lot of putty-knifing, and some sanding in the end to get it smooth, and then a lot of primering to get a clean result.
my DIY paintjob (just did front lip, did plastic sides and rears a few weeks ago)
sorry to hijack lol
Old Apr 12, 2006 | 07:43 PM
lazybrown187's Avatar
Default Re: (sandiegan)
TRY NOT TO GET IT ON YOUR SKIN THAT SHIZZLE BURNS
Old Apr 12, 2006 | 07:48 PM
SD1222's Avatar
Default Re: (lazybrown187)
i've used both before to strip the paint off my old rims and i like the rattlecan better.
Old Apr 12, 2006 | 07:50 PM
DFW's Avatar
DFW
Default Re: (jdm_spoonEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazybrown187 &raquo;</TD></TR><TR><TD CLASS="quote">TRY NOT TO GET IT ON YOUR SKIN THAT SHIZZLE BURNS </TD></TR></TABLE>
I know, it melted my thumb when I first used it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_spoonEG &raquo;</TD></TR><TR><TD CLASS="quote">i've used both before to strip the paint off my old rims and i like the rattlecan better. </TD></TR></TABLE>
There's no paint on it, I'm trying to get the clear coat off.
Old Apr 12, 2006 | 07:53 PM
Krisgh15's Avatar
WERD, doesn't this stuff eat away your tires?
Old Apr 12, 2006 | 09:10 PM
DFW's Avatar
DFW
Default Re: AIRCRAFT Paint Remover (Krisgh15)
bump
Old Apr 12, 2006 | 09:17 PM
crxnj's Avatar
Por-15 works better then aircraft to me..Its way stronger in my opinion..99 cent oven cleaner works also,,have to let it sit for a long time though..
Old Apr 12, 2006 | 09:21 PM
Tad's Avatar
Tad
oh if you can get it in a spraycan definetely do that!
i've got the liquid in a tin,
it's a bEOCH to use, it's more like a goop,
and you'll have to spread it around with ur fingers to get it everywhere it needs to be..
not cool, considering if you get the stuff on ur hands it will BUUUURRNNN
and good lord, if you have a cut or something.. head for the hills.
(no i dont spread it around without gloves )
DFW's Avatar
DFW
Default Re: AIRCRAFT Paint Remover (Mr.speaker)
Well I have a can of aircraft in my garage and I'm just seeing if it would work to take the clear coat off.
Old Apr 12, 2006 | 09:25 PM
Tad's Avatar
Tad
yeah, clear is paint too
so it'll come off
or u could just sand it down and repaint em wutvr u want
Old Apr 12, 2006 | 09:27 PM
DFW's Avatar
DFW
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">yeah, clear is paint too
so it'll come off</TD></TR></TABLE>
Ok cool, thanks
How do I go about covering up my tires though?
Old Apr 12, 2006 | 11:04 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">Ok cool, thanks
How do I go about covering up my tires though?</TD></TR></TABLE>
Old Apr 12, 2006 | 11:14 PM
ekcivic9's Avatar
theres no perfect way to get your tires covered, if you wanna be completely safe, get your tires unmounted and work with just the rim.
Old Apr 12, 2006 | 11:26 PM
DFW's Avatar
DFW
Default Re: (ekcivic9)
slitfill
Sep 23, 2005 08:06 AM
Punker1234
Jul 3, 2005 01:47 PM
zer0zer0 TypeR
May 29, 2002 07:28 AM
xpsonic
Apr 24, 2002 12:44 PM
khoalie
Mar 16, 2002 04:35 PM
