b16 with b17 crank and head?
any sugestions or comments about a b17 crank into a jdm b16 block using a b17 head? i know its real high compression but has anyone done it or heard anything about it?
You are talking about the same thing buddy, the b16 and b17 are phiscally the same, and even their compression is the same. Just that the b17 is older.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">You are talking about the same thing buddy, the b16 and b17 are phiscally the same, and even their compression is the same. Just that the b17 is older.
WRONG!!! Both of you are close but not. Yes both B16 and B17 uses the same block, but the B17 has a slight bigger size crank and longer stroke than the B16. Its do-able puting a B17 crank into a B16.
</TD></TR></TABLE>WRONG!!! Both of you are close but not. Yes both B16 and B17 uses the same block, but the B17 has a slight bigger size crank and longer stroke than the B16. Its do-able puting a B17 crank into a B16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCivicEF9 »</TD></TR><TR><TD CLASS="quote">WRONG!!! Both of you are close but not. Yes both B16 and B17 uses the same block, but the B17 has a slight bigger size crank and longer stroke than the B16. Its do-able puting a B17 crank into a B16.
wouldn't the rod lengths need to be different then?!
Modified by turboLSef at 3:49 PM 4/6/2006
</TD></TR></TABLE>wouldn't the rod lengths need to be different then?!
I dont think I was wrong,of coarse I know the crank has more stroke. He was asking about the block/head. now if you tryed to do b17 crank with b16 rods now thats compression, lol.
</TD></TR></TABLE>I dont think I was wrong,of coarse I know the crank has more stroke. He was asking about the block/head. now if you tryed to do b17 crank with b16 rods now thats compression, lol.
thats what im wanting to do, b16 block, rods, pistons etc. but i want to put the b17 crank in and bump the compression up, i heard 12.9:1 but im not sure, either way i im just woried about valve clearence of course, im just wondering if all will work correctly. if its not compatable ill just do the b17 internals with the b16 block, but has anyone heard of a b16 with a b17 crank and are there any #s for that motor out there
