Hard to star
Old Apr 6, 2006 | 05:48 AM
dgmorr's Avatar
Default Hard to start
Hey there,
I've noticed that after my car has been running and gets up to normal temps, shut the car off, and try to start, it won't start. I have to let it sit for about 5 minutes and then try. What should I look out for? Is this a known symptom of anything?
EDIT: Typo on the title, changing it does nothing...nooob!
Old Apr 6, 2006 | 05:51 AM
egredspools's Avatar
Default Re: Hard to start (dgmorr)
myn did that had to let it cool down dizzy took a **** or should i say the coil did?
could be something else dont get me wrong?
Old Apr 6, 2006 | 06:51 AM
dgmorr's Avatar
Anyone?
Old Apr 6, 2006 | 10:00 AM
dgmorr's Avatar
Old Apr 6, 2006 | 11:35 AM
Targa250R's Avatar
be professional
Could be a main relay problem. Can you hear the fuel pump priming when you turn the key to position "II"?
Old Apr 6, 2006 | 12:42 PM
old man neri's Avatar
Could be as simple as a bad battery or shitty grounds. Starting a car when it is warm takes the most effort out of your starter and battery.
Old Apr 6, 2006 | 12:50 PM
DOWNwithHT's Avatar
We have the same problem with a 91 civic hb. It is really weird, the car starts up and runs/drives great for about 20 minutes. Then, it starts to run like crap and bogs really bad(to the point that the car is undrivable). After it cools completely down, it can be driven again. We switched out the fuel pump and nothing changed...
Old Apr 6, 2006 | 12:58 PM
Default Re: Hard to start (DOWNwithHT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOWNwithHT &raquo;</TD></TR><TR><TD CLASS="quote">We have the same problem with a 91 civic hb. It is really weird, the car starts up and runs/drives great for about 20 minutes. Then, it starts to run like crap and bogs really bad(to the point that the car is undrivable). After it cools completely down, it can be driven again. We switched out the fuel pump and nothing changed...</TD></TR></TABLE>
That actually sounds it's a different problem. The OP is complaining that it is hard to start the car if it is warm.
Old Apr 6, 2006 | 01:23 PM
showcase949's Avatar
Default Re: Hard to start (old man neri)
hum...intresting i have the same problem when its warm and i try to start it it lags....help???
Old Apr 7, 2006 | 11:51 AM
dgmorr's Avatar
Hmm, how do I test to see if it is the main relay?
And yes, I do always here the fuel pump priming when I have the key in the run position.
sl0waccord
Mar 3, 2012 03:13 PM
jkalex05
Aug 31, 2009 10:31 PM
thambi23
Aug 12, 2007 11:29 PM
wreckedmyteg
Apr 20, 2006 09:23 PM
Elemental
Sep 7, 2004 02:08 PM
