99/00 Civic SI instrument cluster in 96-98 Civics
Has anyone used a 99/00 Civic SI instrument cluster in any of the 96-98 Civics (either EX,LX, HX, or DX)?
If you have, is the wiring/plugs the same?-A direct "plug-in" application (while having FULL functionality)?
anyone with firsthand experience???
TIA
TIA
ANY 6th gen civic cluster will work in ANY 6th gen civic simply via plug and play.
this includes
96-00:
CX
DX
LX
EX
GX
Si
Type R
Type R base
VTi
VTi-R
EL
Ri
SiR
SiR II
SE
even the CRV cluster works in ANY 6th gen civic with absolutely no wiring modifications.
this includes
96-00:
CX
DX
LX
EX
GX
Si
Type R
Type R base
VTi
VTi-R
EL
Ri
SiR
SiR II
SE
so then would it change the speedometer readings rpm, etc? or will it read the same as before and basically a look thing?
they will all read correctly. all honda send the same vss, etc signals, its up the cluster on how that is interpreted. so even if you stick lets say a 90 accord cluster in your car...it will read off the correct rpms, speed, temp, gas.
citystars41
Jan 17, 2006 01:08 PM
