obd swap help
1988 Crx Si with b16a obd 0
1988 Crx Hf with b16a obd 1
I'm planning to get this swap off the 1988 Crx Si (obd 0) to the 1988 Crx Hf (which is already wired for obd 1) What exactly do i need to do the conversion from the obd 0 to the obd 1
sorry i'm kinda lost right now i cant even think straight.
So you want to make the engine obd1 to put into the obd1 converted crx ,thats all..? just get an obd1 distributor for the engine..
Dont really understand the question though ?
haha sorry! ok, i suck yes i know.
so all i pretty much need is an obd 1 distributer and a obd 1 ecu? how about injecters and bla bla?
Yeah.. obd1 dizzy,obd1 ecu,4 wire heated o2..
For the injectors you can keep the stock obd0 injectors as long as you keep the injector resistor box..Did the person put in obd1 injector clips already.? Because they're different then obd0.
5_Lug_B
Jul 3, 2007 06:00 PM
