Any tips on welding thin AL tubing to thicker flanges?
Old Apr 5, 2006 | 06:33 PM
Fred Allen Burge's Avatar
Default Any tips on welding thin AL tubing to thicker flanges?
Hey,
I'm trying to weld some 1/16th" tubing to some 1/4" flanges but I can't get a good puddle on both pieces at the same time. I can get a puddle on the 1/4" flange with no problem of course but getting it to "blend" into the tubing is really, really tough! The rod just piles up and makes a mess or I burn through the thin tube.
I've seen some really nice looking welds on aftermarket intake tubes so I know this can be done I just don't know how.
Does anybody have any helpful tips here or can you you explain your technique for this?
Thanks
Fred
Old Apr 5, 2006 | 06:37 PM
dfoxengr's Avatar
Default Re: Any tips on welding thin AL tubing to thicker flanges? (Fred_Allen_Burge)
you need to move really fast once it's going. direct your arc on the thicker part for all most all the time.
you might need a friend to put a propane torch on the back of the thick to keep it hot.
k24em2's Avatar
Use the filler to convince the puddle onto the tubing.
Old Apr 5, 2006 | 07:30 PM
fabnewb's Avatar
Default Re: Any tips on welding thin AL tubing to thicker flanges? (k24em2)
preheating is your friend
Old Apr 6, 2006 | 04:23 AM
stackz's Avatar
at the jetties fishin'
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Use the filler to convince the puddle onto the tubing.</TD></TR></TABLE>
yeah, I also like to bevel the larger flange and sorta stick the thin tube down into it and then (kinda weird to explain) weld more towards the flange than the tube and let the puddle just fall into the bevel.
I do this around and then I go back and lay down the beads on top of this.
Old Apr 6, 2006 | 05:07 AM
Default Re: Any tips on welding thin AL tubing to thicker flanges? (stackz)
Thanks for the tips guys, anybody have any pics of their welds of this type?
thanks again,
Fred
Old Apr 6, 2006 | 06:17 AM
dfoxengr's Avatar
not just preheating but during-heating.
Al gets rid of heat really fast.
Old Apr 6, 2006 | 09:46 PM
vtecspeed1320's Avatar
Shooting Star
I weld alum. all day get your puddle going and do a motion that would be kind of like dragging from the thicker metal to the thinner, and do it quickly!!!
Old Apr 7, 2006 | 04:36 AM
ManBearPig4silly's Avatar
Default Re: (vtecspeed1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 &raquo;</TD></TR><TR><TD CLASS="quote">I weld alum. all day get your puddle going and do a motion that would be kind of like dragging from the thicker metal to the thinner, and do it quickly!!!</TD></TR></TABLE>
yeah what he said. You can kind of maintain your puddle on the thicker part and consistently weave the torch al tiny bit to the side to carry the puddle onto the thinner material. Kind of like pulsing the heat input on the thinner stock.
Old Apr 7, 2006 | 10:24 AM
Thanks for the description! That's basically what I tried but I couldn't seem to get the thin tube hot enough for the puddle to blend into it. I'll try some more though.
thanks
Fred
Old Apr 7, 2006 | 11:29 AM
Shooting Star
are you MIG or TIG?
Old Apr 7, 2006 | 08:39 PM
kawgomoo's Avatar
put the flange in the oven at about 350-400 degrees for 20 mins. then weld it.
oh yeah use gloves
.RTErnie
Welding / Fabrication
23
Aug 3, 2007 12:51 PM
melovesboost
12
Apr 22, 2007 06:26 PM
Evile140
Dec 27, 2005 01:01 PM
1.8
Mar 4, 2005 03:38 PM
Want2race
Feb 16, 2005 04:12 AM
