installed timing belt, forgot EXHAUST cam gear .....
had to remove my timing belt because my water pump was bad, but then i reinstalled the
timing belt and aligned ALL TIMING MARKS on the crank and cam pullies, but i forgot that my exhaust cam gear was advanced 4 degrees !!!!!!
wtf do i need to do now to resovle it ?
do i need to remove the timing belt and reinstall it after resetting the cam gears to 0,0, or can i loosen the cam gear and rest timing, then re advance the exhaust cam ?
wtf do i do .
sometimes i do the dumbest **** !!!
thanks guys
wtf do i do .
thanks guys
The marks on the cam gears should still line up no matter what. Confirm with the inner markings with the adjustable sproket that its still advanced 4*. Your probably fine.
scoob8000
Dec 19, 2011 11:57 AM
Civicman86
Jun 24, 2006 07:12 AM
EK4 hatchback
May 31, 2004 08:45 PM
