which clutch should i use?
Old Apr 5, 2006 | 05:07 PM
rice a roni's Avatar
Default which clutch should i use?
i have a 88 crx hf tranny and im going to put it int o my 90 crx. can someone give me the spline counts on the shafts for all years?
Old Apr 5, 2006 | 05:10 PM
si0385.'s Avatar
use a clutch disk from a 87 prelude 2.0 si and you will be good to go
Old Apr 5, 2006 | 05:37 PM
Default Re: (si0385.)
wtf? no seriously...
Old Apr 5, 2006 | 06:41 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">use a clutch disk from a 87 prelude 2.0 si and you will be good to go</TD></TR></TABLE>
Old Apr 5, 2006 | 06:44 PM
silentdork818's Avatar
Default Re: (Crx Jimmy)
or 86-89 Accord (any model)
Old Apr 6, 2006 | 02:50 AM
Default Re: (silentdork818)
can i just get a new clutch and flywheel set up?
Old Apr 6, 2006 | 07:37 AM
bagpipe goatee's Avatar
well, 88 has different splines and a smaller flywheel. 90 has a larger flywheel the prelude mentioned has the same size flywheel as the 90-91 civic/crx, but has the same splines as the 88 civic/crx.
Old Apr 6, 2006 | 01:27 PM
Default Re: (bagpipe goatee)
so umm...use my 90 crx clutch but get a flywheel from a prelude? is that all i need? remember the tranny is an 88.
Old Apr 6, 2006 | 01:45 PM
Mugencrxsir1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">well, 88 has different splines and a smaller flywheel. 90 has a larger flywheel the prelude mentioned has the same size flywheel as the 90-91 civic/crx, but has the same splines as the 88 civic/crx.</TD></TR></TABLE>
I believe they have 26 or 27 splines, you will have to count, or just search. The different splines have been covered before.
Old Apr 6, 2006 | 05:33 PM
Default Re: (Mugencrxsir1)
You can use all of the 90 clutch stuff (flywheel, pressure plate), but you have to use a 85-87 Prelude 2.0/86-89 Accord clutch disc because it is the same size as the 90-91 Civic disc (212mm) and it has the right spline count for the 88 style tranny (21 splines). You can get any kind you want...for example i know ACT sells their stuff seperately so you can mix and match this stuff to fit your car.
Old Apr 6, 2006 | 05:48 PM
alright thanks dork...holy chit..your name is dork..sorry i just thought that was funny...lol...thanks again.
Old Apr 7, 2006 | 04:26 AM
VRD^don's Avatar
Default Re: (rice a roni)
umm dont make fun of the people that helped you..you should be glad there hellping you..
Old Apr 7, 2006 | 12:40 PM
Default Re: (option_2)
i didnt dude just pointing it out.
Tyson
May 3, 2008 11:21 PM
agendadjs
Dec 8, 2007 04:56 PM
ls19integra95
May 4, 2007 03:21 PM
DA91TEGGY
Jul 22, 2005 01:19 PM
