clutch issues!!
Old Apr 5, 2006 | 01:44 PM
spurge's Avatar
Default clutch issues!!
earlier today i was driving and i sank the clutch but it did not pop up, its stayed floored to the ground, then after awhile the clutch went back to normal. why did this happen and how can i fix this issue.
Old Apr 5, 2006 | 06:23 PM
hondadude's Avatar
Default Re: clutch issues!! (spurge)
This always seems to happen on those 1958 accords with the 10 speed transmission, if you have a chance check the fluid in the clutch master reservoir.
While you are under the hood doing that, look for a sticker that says WHAT YEAR THE CAR IS. Then look under the dash to see if the clutch master is puking fluid out the end of it.
Old Apr 5, 2006 | 07:01 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: clutch issues!! (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">This always seems to happen on those 1958 accords with the 10 speed transmission, if you have a chance check the fluid in the clutch master reservoir.
While you are under the hood doing that, look for a sticker that says WHAT YEAR THE CAR IS. Then look under the dash to see if the clutch master is puking fluid out the end of it.</TD></TR></TABLE>
I wouldn't have gone that extreme but the principle remains the same.
Old Apr 5, 2006 | 10:38 PM
gianinline's Avatar
....members keep forgetting that they must say: what year, model, and issue on title of their topics.....
It is annoying....
BseriesHeaven
Mar 6, 2007 02:55 PM
russianswty
Feb 1, 2007 12:02 AM
KloC 95 EG
Mar 13, 2006 09:18 PM
budget
Mar 30, 2005 02:25 PM
plusONE jboy
Apr 23, 2004 04:42 PM
