?? shave head on 98 CBR 900
Anyone here know what is the max you can shave a head of a 98 CBR 900. I want to raise the compression ratio, to sqeek out some extra power.
[Modified by nsxxtreme, 8:24 PM 4/5/2002]
Why not just getting a thinner head gasket? I know HRC makes em for the 600's to bump em up a point or two, and I would bet so on the 900rr as well. Would definately be cheaper and less permanent if you wanna change it back. I know two brothers can get HRC parts, and I am assuming the honda dealer should be able to get em for ya.
Steven
Steven
You'd be better off going with a set of high-compression pistons from JE or Erion Racing. There is very little margin for shaving the head or the cylinder block, and one screwup means expensive replacement parts. Pistons can be found here:
http://www.kyleusa.com/prod032.htm
http://www.streetfighters-usa.com/er...ne_pistons.htm
http://www.erionracing.com/
...Just to name a few...
Thanks for the info guys but the difference in price in shaving the head and replacing the pistons is about $600.00 I have done this before on other bikes, just never the CBR.
To the others that had some suggestions thanks, do you have web site info?
InfamousRS
May 2, 2002 12:58 PM
