FS:NA B-series Parts, Civic, Integra, Suspension, Brakes, SMSP, RLZ, Koni...Always Updated!
<FONT COLOR="red"><FONT SIZE="4">THIS POST WILL BE UPDATED REGULARY SO KEEP CHECKING
BACK!!!</FONT></FONT>
I will ship after payment is received. I will ship USPS Priority Mail for smaller items and FedEx ground for larger items. I will also include a tracking number or delivery confirmation number. I accept money orders, Paypal, and also pickup in the NJ area.
I have many references and vouches here on H-T, just ask around or I can send you a list.
Contact Info
AIM - Dynoair690
E-Mail - Dynoair690@aol.com
Paypal - Dynoair690@aol.com
Please click on the thumbnails for larger images
<u>Action 1MD Clutch</u>
-Used for 600 miles, broken in correctly
-6 puck, unsprung
-Great condition, barely any use at all
-For Hydro B-Series
$300 Shipped
<u>B-Series Clutch Slave Cylinders</u>
-All in great working condition, one has only 500 miles on it
$25 Shipped Each
<u>Built GSR Clyinder Head</u>
-From my 2001 GSR, I will include a copy of the title with the sale
-4000 miles since rebuild
-RLZ Portwork, complete port and chamber work
-Valves de shrouded to 84.5mm, chamber volume is 42ccc
-RM Gen1 Outer valvesprings installed (will include inner springs)
-RM Ti Retainers
-RLZ Modified LMA’s
-Manley STD Valves
-New vavle guides and seals installed 4000 miles ago
-Everything else in the head is in great condtion, includes Vtec Solenoid
-Made 230whp with a 2.0lt 11.5:1 C/R block
$1850 Shipped
<u>Skunk2 Intake Manifold</u>
-For GSR head only
-Full race port and polish, was cut open, ported and welded back up
-TB opening ported to 70mm
-This manifold made 230whp on a 2.0lt GSR engine
-Great condition
$550 Shipped
<u>1993 LS B18A Intake Manifold </u>
-Great condition
$30 Shipped
<u>1st Gen B16 Intake Manifold</u>
-Great condition
$30 Shipped
<u>1993 LS B18A Throttle Body</u>
- Great working condition
- Includes TPS sensor
$45 Shipped
<u>RLZ Stage 3 B-Series Cams</u>
-Used for only 3000 miles, great condition
-Great for serious all-motor setups
$600 Shipped
<u>Hondata S200 w/P06 ECU</u>
-P06 is converted to Vtec
-Plug and play, ready to go
-You need to have a basemap created by your tuner, none included
$360 Shipped
<u>OBD2-B P72 ECU</u>
-From my 2001 GSR, good working condition
$75 Shipped
<u>OBD1 P07 ECU</u>
-From my 94 Civic VX, good working condition
$60 Shipped
<u>Generic GSR Short Ram Intake</u>
Short ram, includes air horn
$40 Shipped
<u>OBD-1 B-Series Vtec Distributor</u>
-Brand new, only installed and timing set
$180 Shipped
<u>JDM ITR Valve Cover W/Extras</u>
-Includes Comptech oil cap
-Cut for cam gears, with matching timing belt cover
-Great condition, no scratches or paint missing
$185 Shipped
<u>3" Magnaflow Muffler</u>
-Brand new, in box, never used
-3" in, 3" out, center, 14" body
$75 Shipped
<u>Integra Rear Mount</u>
-Works for 92-00 Civic and 94-01 Integra
-Great condition, taken off a 96 GSR
$30 Shipped
<u>Integra Upper Timing Belt Side Mount</u>
- Great Condition
$35 Shipped
<u>90-93 Integra Timing Belt Mount Brackets</u>
-Removed from 90-93 Integra’s
-Both in great condition
$25 Shipped Each
<u>2001 GSR Fuel Pump</u>
-Great working order
$40 Shipped
<u>B-Series Timing Belt Tensioners</u>
-All in great working condition with low miles
$30 Shipped Each
<u>B-SeriesTiming Belt Crank Gears</u>
-All gears in great condition
- (2) OBD1
- (1) OBD2
$30 Shipped Each
<u>LS/B16/B20 Windage Tray</u>
-Dirty but not bent or bad
$15 Shipped
<u>(2) B-Series Rear Main Seal Cover</u>
-Good Condition
$20 Shipped Each
<u>(2) B-Series Rear Breather Boxes</u>
$20 Shipped Each
<u>B-Series Ignition Coils</u>
-Both in good working condition
$20 Shipped Each
<u>Civic VX Exhaust Manifold</u>
-Upper section used for home made turbo kits
-Great condition
$40 Shipped
<u>OBD1 SOHC Alternator</u>
-Perfect working condition
-Off my 94 Civic VX, Includes lower aluminum mount
$50 Shipped
<u>OBD1 SOHC Starter</u>
-Off my 94 Civic VX
$50 Shipped
<u>ITR Airbox</u>
-Great condition, includes airbox and filter
$45 Shipped
<u>900lbs HyperCoil Springs</u>
-8” Length, 900lbs, great condtion
-Will work with Skunk2, Omni, and GC Coilovers
-Great for Drag Racing rear springs
$110 Shipped
<u>Koni SS shocks</u>
-Rear for 88 CRX and ITR control arms
-Race valving from Koni to handle higher spring rates that off the shelf Koni’s
-Brand new, never used
$250 Shipped
<u>OEM Integra Shocks</u>
-2 front, 1 rear
-Good condition
$40 Shipped
<u>Civic VX 30/30 Prop Valve </u>
-Great condition
$25 Shipped
<u>1995 GSR Brake Booster</u>
-Perfect condition
$55 Shipped
<u>1995 GSR Brake Master Cylinder</u>
-Good condition
$55 Shipped
<u>2001 GSR Cruise Control Module</u>
$40 Shipped
<u>Hondata Intake Manifold Gasket</u>
SOLD to 95 integra
<u>Machined Crank Pulley</u>
SOLD to blkcivicpn0i
<u>Datum 1 Fuel Rail</u>
SOLD to Rota92
<u>Iceman Headlight Intake Scoop</u>
SOLD to Egyptian_Kid
<u>B-Series Alternator Brackets</u>
Sold to GSRCRXsi
<u>B-Series Integra A/C Mount Bracket</u>
SOLD
<u>Tokico Blue Shocks</u>
SOLD to drewthomas14
<u>NGK Spark Plug Wires</u>
SOLD to 91' LS-VTEC
<u>B-Series Shift Linkage</u>
SOLD to shrums1la
<u>OBD2 Lower Timing Belt Cover</u>
SOLD to r.p.m
<u>40/40 Non-ABS Prop Valve</u>
SOLD to4door_demon
<u>JimFab Mounts</u>
SOLD to zclee.com
<u>OEM Denso O2 Sensors</u>
BOTH SOLD
<u>Fake J’s Intake</u>
SOLD to datnigabluberry
<u>OBD-2 B-Series Alternator</u>
SOLD to StreetRacerVL
<u>Skunk2 Short Shifter</u>
SOLD to JoeDeMango
<u>CFK Sensor</u>
SOLD to Vwang924
<u>CFK Sensor and Gear</u>
SOLD to Sasap
<u>B-Series Integra Timing Belt Post Mount</u>
SOLD to SiLuck2
<u>Built 2.0lt 11.5:1 c/r GSR Shortblock</u>
SOLD to sly_106
<u>AEBS Head Studs</u>
SOLD to sly_106
<u>Ground Control Coilovers</u>
SOLD to TodaParty
<u>OBD2 B-Series Vtec Distributor</u>
SOLD to SlepT ej6
<u>ST Corsa Cam Gears</u>
SOLD to CRXnorway
<u>B-Series Front Transmission Mount Bracket</u>
SOLD to El_cOuZiN
<u>2000 B16 Throttle Body</u>
SOLD to civicdxtyper
<u>B-Series Clutch Line</u>
SOLD
<u>B-Series Passenger Torque Mount</u>
SOLD
<u>Edelbrock Intake Manifold</u>
SOLD to Muckman
<u>VX 5-Wire O2 Sensor</u>
SOLD
<u>USDM ITR Transmission </u>
SOLD to drift4jesus
<u>Clutchmasters Lightweight Flywheel</u>
SOLD
<u>Integra/Civic Clutch Master Cylinders</u>
Both SOLD
<u>1994 Civic VX Stock Intake Tube and Airbox</u>
SOLD to Skunk.Werks
<u>B-Series Starter</u>
SOLD to brokeHonda
<u>B-Series Upper Transmission Mount</u>
SOLD to brokeHonda
<u>B-Series Speed Sensor</u>
SOLD
<u>GSR Front Brake Conversion</u>
SOLD
<u>GSR Rear Brake Conversion </u>
SOLD
<u>OBD1 Civic DX Engine Harness</u>
SOLD
<u>B-Series Axles</u>
SOLD
<u>SMSP B20Vtec Header</u>
SOLD
<u>RPM Services Throttle Body</u>
SOLD
<u>B-Series Halfshaft</u>
SOLD
<u>GSR Oil Squirters </u>
SOLD
<u>Bosch O2 Sensor</u>
SOLD
<u>UR B-Series Pulley</u>
SOLD
<u>OBD2 Integra GSR Engine Harness</u>
SOLD
<u>B18B Water Pipe and Thermostat Housing</u>
SOLD
<u>B-Series Integra Rear Mount Bracket</u>
SOLD
<u>OBD-2 GSR Purge Valve</u>
SOLD
Modified by Big Teggie at 6:36 PM 6/28/2006
Contact Info
AIM - Dynoair690
-6 puck, unsprung
-For Hydro B-Series
$300 Shipped
$25 Shipped Each
-RM Ti Retainers
-RLZ Modified LMA’s
-Manley STD Valves
$1850 Shipped
-For GSR head only
-Great condition
$550 Shipped
-Great condition
$30 Shipped
-Great condition
$30 Shipped
$45 Shipped
$600 Shipped
$360 Shipped
$75 Shipped
<u>OBD1 P07 ECU</u>
$60 Shipped
$40 Shipped
$180 Shipped
$185 Shipped
$75 Shipped
$30 Shipped
- Great Condition
$35 Shipped
$25 Shipped Each
$40 Shipped
$30 Shipped Each
- (2) OBD1
- (1) OBD2
$30 Shipped Each
$15 Shipped
-Good Condition
$20 Shipped Each
$20 Shipped Each
$20 Shipped Each
-Great condition
$40 Shipped
$50 Shipped
-Off my 94 Civic VX
$50 Shipped
<u>ITR Airbox</u>
$45 Shipped
$110 Shipped
$250 Shipped
-2 front, 1 rear
-Good condition
$40 Shipped
-Great condition
$25 Shipped
-Perfect condition
$55 Shipped
-Good condition
$55 Shipped
$40 Shipped
SOLD to 95 integra
SOLD to Rota92
Sold to GSRCRXsi
SOLD
SOLD to 91' LS-VTEC
SOLD to shrums1la
SOLD to r.p.m
SOLD to4door_demon
SOLD to zclee.com
BOTH SOLD
SOLD to JoeDeMango
<u>CFK Sensor</u>
SOLD to Vwang924
SOLD to Sasap
SOLD to SiLuck2
SOLD to sly_106
SOLD to sly_106
SOLD to TodaParty
SOLD to SlepT ej6
SOLD to CRXnorway
SOLD to El_cOuZiN
SOLD
SOLD
SOLD to Muckman
SOLD
SOLD to drift4jesus
SOLD
Both SOLD
SOLD to Skunk.Werks
SOLD to brokeHonda
SOLD to brokeHonda
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
SOLD
interested in the iceman intake scoop.. i m in jersey will get in touch with you later this week
