Suspension & Brakes Theory, alignment, spring rates....
Koni: Question about fitment
Old Apr 5, 2006 | 10:58 AM
. x A t t a c k's Avatar
Default Koni: Question about fitment
I tried to do a search but nothing came up. Or I just suck at searching. So I made this thread hoping someone would answer my question. My question is would koni yellow for a crx fit a '94 integra as long as it has the itr lca?
Any help would be greatly appreciated!
Old Apr 5, 2006 | 11:30 AM
kaiba's Avatar
Default Re: Koni: Question about fitment (. x A t t a c k)
According the part number for the koni yellow all the front have are the same. 88 crx and itr have the same rear. non-R and all 89-91 civic/crx/del sol have the same rear. Not to sure about the 96-00.
Old Apr 5, 2006 | 11:42 AM
I just checked out koni's site. The rear from an '88 have the same part number as the itr. The front doesn't match up. So I guess the front wont fit?
Front shocks.
Honda 88 Civic, CRX
8041 1166SP4
Acura 94-01 Integra
8041 1152
Rear shocks.
Honda 88 Civic, CRX
8041 1164Sport
Acura 94-01 Integra
8041 1164Sport
Old Apr 5, 2006 | 01:08 PM
CRX Lee's Avatar
Default Re: (. x A t t a c k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . x A t t a c k &raquo;</TD></TR><TR><TD CLASS="quote">front doesn't match up. So I guess the front wont fit?
You are generally correct on the front. If you are using a coil-over sleeve system and take the smaller ID front mounting fork from the CRX over to the Integra then you will be okay.
Normal fit with spring seat = no
Swap the lower mount fork and use coil-over system = yes
t0ekn3e
Suspension & Brakes
Jan 5, 2007 05:09 PM
Zeppelin
Jul 8, 2004 02:15 PM
Shawn01
Dec 8, 2003 09:14 AM
Cryptopsy
Jan 29, 2003 12:58 PM
Cryptopsy
Jan 29, 2003 12:33 PM
