Suspension & Brakes Theory, alignment, spring rates....
Is this a good time to replace my front wheel bearings?
Old Apr 5, 2006 | 09:27 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Is this a good time to replace my front wheel bearings?
In a week or two, I'm going to be doing a lot of drivetrain work to my car:
- no-grinds Z6 tranny
- new axles
- Brembo slotted rotors, Axxis Metal Masters pads, fluid (duh)
- replacing broken front wheel stud
Should I replace the wheel bearings while I'm in there, or is it not worth it if they're in good shape?
Old Apr 6, 2006 | 02:56 PM
Default Re: Is this a good time to replace my front wheel bearings? (boostincoupe)
bump
Old Apr 6, 2006 | 02:58 PM
Relic1's Avatar
if you can get the new stud in without pressing out the hub, which always screws up the bearing.
Then I don't see a need to replace the bearing. What mileage do they have on them?
eastbayrep
May 7, 2010 05:50 PM
boostincoupe
Apr 5, 2006 07:21 AM
Ricochet.
16
Dec 11, 2004 12:50 AM
valve79
Oct 26, 2004 01:51 PM
James
Sep 1, 2004 04:47 PM
