Finding bad ground
Old Apr 5, 2006 | 07:08 AM
Mr.Death's Avatar
Default Finding bad ground
I just put my car back on the road but I am having a problem with my battery draining itself when the car is off. I put a multimeter in between the neg battery terminal and the negative battery wire as stated in my helms manual and have found that something is draining my battery(short in wiring system). I unplugged the alternator to see if that was the prob but I am still getting the drain. If anybody could give me some tips or pointers I'd appreaciated greatly as I am sick of having to boost my car when I need to go somewhere. My car is a 90 CRX SI if this helps.
Old Apr 5, 2006 | 07:25 AM
ITRnorway's Avatar
Default Re: Finding bad ground (Mr.Death)
i had the same problem with my car and there was one cell inside the battery that was "dead"/ connected to ground so the battery was draining it self from power.
that was also after taking the car out from long time storage
Old Apr 5, 2006 | 08:55 AM
thesmogman's Avatar
Til you find it, for now you can install a terminal with a power cut off on it. They are like $10 bucks.
As for finding the short, Keep the voltmeter hooked up the way you have it and start pulling the fuses one at a time til you find the one with power. That will get you to the circut. Then just troubleshoot the circut.
Good luck Mr. D
Old Apr 5, 2006 | 10:48 AM
Mr.Death's Avatar
Default Re: Finding bad ground (thesmogman)
Thanks for the replies. I WILL get to the bottom of this!!!
fix_my_car
Oct 10, 2010 06:08 PM
BIG_WILL
Nov 16, 2008 07:06 PM
itr501
Jul 31, 2007 10:32 PM
crxh22project
Mar 14, 2005 04:52 PM
sky88
Jul 17, 2004 11:30 AM
