weird question
ok, after the swap, i just noticed in my ek my right turn signal doesnt work when my headlights are one. it's fine if its off or if its only the parking light. any ideas what would cause this? occasionally if i leave it clicked on right, it would flash once but that's it. the left signal works all the time.
I had the same problem with my rear wiper once. It would only work when I pushed the brakes. I found out that the insulation on the wires was worn and they were shorting together.
Check to see if yours are stripped down somwhere and touching the headlight wires, which may also be worn.
haha yeah, I didn't do anything to my wires either, they just got worn.
You're welcome, I hope it helped, and I hope it doesn't turn into a bigger problem like mine did.
Mine got to the point where my whole gauge cluster would flash and blink and generally be on crack when the headlights were on. I could never find the problem, but I'm guessing it was a short somewheres.
Good luck
Mine got to the point where my whole gauge cluster would flash and blink and generally be on crack when the headlights were on. I could never find the problem, but I'm guessing it was a short somewheres.Good luck
kefka
May 22, 2003 11:23 AM
