1/4 window molding replacement.
Old Apr 4, 2006 | 10:08 PM
Nevaeh Speed's Avatar
Default EG hatch 1/4 window molding replacement.
Any body every pulled the 1/4 windows out and changed the molding? I was wondering if this window could be removed without breaking it. Anybody got a how to, or some helpful hits? This would be on a eg hatch fellas.
Old Apr 5, 2006 | 05:31 AM
-Gary-'s Avatar
Default Re: EG hatch 1/4 window molding replacement. (Nevaeh Speed)
Are you talking about the moulding at the bottom of the windows on the doors? If so, I just scraped the old rubber off the top, masked off the rest of the car and painted them black. I also removed my wiper arms and painted thos black too. I even put a coat of clearcoat on them to make 'em look even better.
Old Apr 5, 2006 | 09:58 AM
Nope not the doors. I have the new molding for that. I'm talking about the windows behind the doors, the 1/4 windows.. The ones you can't roll down.
Old Apr 5, 2006 | 11:46 AM
manueliscool's Avatar
Default Re: (Nevaeh Speed)
I'd imagine you would use "piano wire" i think thats what its called. basically thick fishin wire and try to get one end from the outside in or inside to out. and once you got it thru pull the wire to cut the glue holdin the window on. and once the window is off try using a chisel or a blade to scrap off the glue on the window and the same for the car but carefully so u wont expletive up your paint. Don't quote me on this cuz i havent done this yet but id imagine thats how u would do it. that or either with a heat gun but id think it be easier to do it with the wire. Peace
And if you figure it out do a write up if u can. Peace! by the way nice car!
Old Apr 5, 2006 | 08:03 PM
Thanks... And thats not my car, it's a friends. I just got mine back from the paint shop, and I cut out the rubber, so I could put new rubber in. I'll post up pics when she's all back together.
Old Apr 5, 2006 | 09:12 PM
dohcdelsol's Avatar
my old gsr i had to cut away all the rubber from inside and out and slide the window out on a weird angle. clean it up once out. then slide it back in and get the new molding it. It was a bitch job and i ended up shatterin the window when put back it
Old Apr 7, 2006 | 07:55 PM
I was thinking about getting quotes from a few window shops and just see how much they'll charge.
Gsr94black
Feb 23, 2012 06:15 AM
DazeMS
Jan 21, 2010 05:29 PM
bopbop93030
Nov 20, 2008 09:03 AM
90hatchie
Nov 10, 2004 11:52 AM
sirminder
Aug 31, 2003 05:19 AM
