Crank pulley Question ~
is the crank pulley on itr with a/c & without a/c the same?
(fron the factory no a/c) vs (factory a/c equiped R)
what happends if you use light flywheel + light crank pulley like CTR N1 pulley?
A nice cheap option for a race car, take your stock 3 groove OEM pulley to a machine shop and have the A/C & PS grooves cut off. It's lighter and still has the OEM harmonic dampner.
I have a ctr pulley, and a light flywheel, all is well here... i am pulling my flywheel out tho and replacing it along with the clutch and pressure plate... needs to be replaced
I also think i am going to change my crank pulley to something even lighter in the future
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">is the crank pulley on itr with a/c & without a/c the same?
(fron the factory no a/c) vs (factory a/c equiped R)</TD></TR></TABLE>
Yes, all the crank pulleys had provisions for the A/C belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QUOTE=itr1244 »</TD></TR><TR><TD CLASS="quote">what happends if you use light flywheel + light crank pulley like CTR N1 pulley?</TD></TR></TABLE>
No more or less (longevity-wise) than if you were running a stock flywheel with the pulley.
b18sihatch
17
Mar 7, 2006 12:21 AM
IGotNoSwap
21
Sep 27, 2005 08:17 PM
