Fuel sender voltage
Old Apr 4, 2006 | 07:34 PM
Batoutahell's Avatar
Default Fuel sender voltage
My fuel gauge is stuck on E. I unclipped the connector at the sending unit, jumpered the wires, and the gauge does slowly rise. I take it the gauge is functioning.
Here's the problem: when I probe both wires with the ignition ON, I only get 6 volts. I think I should be reading battery voltage. I tested the ground wire, (G511) it's okay. I checked the #1 10A fuse, it's okay.
Is the only thing left to check the continuity of the yel/wh wire? I doubt the yel/wh wire has a break, because if there was a break in that wire, I don't think I'd be reading any voltage. I assume it's a problem that I'm only reading 6 volts. Any suggestions why I'm not reading battery voltage?
Old Apr 5, 2006 | 10:32 AM
Default Re: Fuel sender voltage (Batoutahell)
Anybody?
Old Apr 5, 2006 | 10:44 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Could also be bad ground..
Here are the pages from the manual:
After you click on the imagine ,click again for full size:
Old Apr 5, 2006 | 12:52 PM
Default Re: Fuel sender voltage (88DXCRX)
Thanks for the images. I did test the ground by running my voltmeter lead straight to the G551 ground bolt located next to the hatch latch. I'm still getting only 6V. Is there a resistor somewhere in the circuit? I guess I'll search for the ecu pinout for the yel/wh wire and check for a break.
91(si)hatchey
Jul 29, 2009 08:16 AM
cehcivic15
Sep 24, 2008 12:19 PM
G2ILS
Jan 17, 2005 12:14 PM
rice r0cket
11
Jul 5, 2004 03:43 PM
