10w-30, 10w-40 or Honda MTF for my 94gsr tranny?
Old Apr 4, 2002 | 03:18 PM
mickey513's Avatar
Default 10w-30, 10w-40 or Honda MTF for my 94gsr tranny?
I have a 94gsr and the owner's manual suggest using 10w-30 or 10w-40 for the transmission.
Those with the 94-95, which weight oil do you use? 10w-30 or 10w-40? Which one will give a smoother shift?
Also, how about Honda MTF? Is that ok to use on a 94gsr tranny?
Old Apr 4, 2002 | 03:21 PM
shattergsr's Avatar
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (mickey513)
well I just recently bought a 94 gsr but the previous owners oil change records were 10w-30..hope that helps...
Old Apr 4, 2002 | 03:22 PM
JL 74's Avatar
25 Year Member
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (shattergsr)
For trannies, they normally use 10w40 but either one should be fine.
Old Apr 4, 2002 | 04:49 PM
Farnsrocket's Avatar
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (jl74)
Use the Honda MTF. Not worth ruining your tranny.
Old Apr 4, 2002 | 04:59 PM
Charles B.'s Avatar
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (Farnsrocket)
i use 75W-90 mobil 1 synthetic gear oil
Old Apr 4, 2002 | 06:16 PM
keys's Avatar
just use Honda MTF..... I actually just replaced my oil and tranny fluid just an hour ago.
Old Apr 4, 2002 | 06:54 PM
lazyguy's Avatar
get the honda **** motor oil isnt made for a tranny
Old Apr 4, 2002 | 08:45 PM
iH8RICERZ's Avatar
I got a 94 gsr and i put redline tranny fluid...works great...and shifts like butter now!
Old Apr 4, 2002 | 09:09 PM
JL 74's Avatar
25 Year Member
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (b18cURmama)
This according to Honda when they introduced and spent $$$ marketing their MTF. But all pre 1997? models calls for 10w30 or 40 for manual trannies.
As far as I know, no significant changes occured b/t 1997 and 1998 Teg trannies.
Old Apr 4, 2002 | 10:30 PM
mickey513's Avatar
Yeah, I'm sticking with 10w-30 or 10w-40. I know the newer gsr come with Honda MTF fluid stock but my 94GSR right now shifts really smooth........however, it's time for a MT Fluid change. I just want to know which weight oil to use so I can get the best possible shift/smooth shift.
Old Apr 5, 2002 | 12:13 AM
keys's Avatar
does your 1994 manual say to use motor oil? I need to check out my manual again
Old Apr 5, 2002 | 01:20 AM
keys's Avatar
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (keys)
I just checked my Helms manual and it does say SAE 10w-30 or 10w-40. I always heard that motor oil doesn't belong in a transmission, but I wonder....... Will my 1994 tranny shift better if I change my transmission fluid from Honda MTF to 10w-30 or 10w-40 motor oil?
Old Apr 5, 2002 | 05:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You are NOT supposed to use motor oil in the tranny. You ARE however supposed to use a lubricant that conforms to 10w30 specs. 75w90 is NOT the right stuff, it's too thick and will probably mess up your tranny over time. I suggest using either Honda MTF or Redline MTL (conforms to 10w30 specs). Do not use Redline MT90, that confroms to 75w90 specs.
Old Apr 5, 2002 | 05:48 AM
GSRaCeRbOI's Avatar
i used honda MTF in the 95
Old Apr 5, 2002 | 06:48 AM
mercury's Avatar
New User
Use Honda MTF. People who put in synthetic either have the experience of it shifting really well, or it blowing up their tranny (probably because it's not exactly 10W30 spec). Don't take that risk!
Old Apr 5, 2002 | 07:49 AM
Community Builder
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (mercury)
That should not be a problem w/ the Redline MTL, as it conforms to the 10w30 specs, and also has the proper friction additives for proper synchro operation (same as Honda MTF), and is synthetic, too.
Old May 3, 2002 | 09:27 AM
VTEConly's Avatar
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (PatrickGSR94)
How many Qts of Honda MTF do our trannies take exactly? I think it's 2.5-3 if I remember correctly? I can't find the owner's manual right now. The wife has shoved it somewhere and I 'll probably never find it.
I have 3 qts (that I bought for my older Civic and never used it) and want to get to replace it this weekend. Is 3 enough? Is it also ok if this MTF has been sitting in the garage for 1yr?
Old May 3, 2002 | 01:32 PM
VTEConly's Avatar
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (VTEConly)
Old May 3, 2002 | 03:31 PM
JV's Avatar
JV
Who?
A mechanic i know at the Honda dealer near me told me to save my money and just use the 10w30..........
Old May 3, 2002 | 04:16 PM
denieone's Avatar
just what he said..........
is just 4.43 Q. if you get it at the dealer
Old May 3, 2002 | 04:27 PM
denieone's Avatar
yes.........
you'll end up using 2 1/2............
Old May 6, 2002 | 07:51 AM
VTEConly's Avatar
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (denieone)
thanks Demieone!
BTW, I paid $3.50/qt last year from http://www.hparts.com but I ordered lots of other stuff too so I didn't get killed in shipping. It's worth buying as much as you can so the shipping doesn't kill the good prices you get ordering on-line.. I ordered 10 oil filters, plugs, etc + the 3qts of MTF and shipping was under $10. I still saved $15+
Old May 6, 2002 | 08:57 AM
Community Builder
Default Re: 10w-30, 10w-40 or Honda MTF for my 94gsr tranny? (JV)
He was probably hoping your tranny would go south eventually and that you would bring it in there for them to replace it.
Once again, you should NOT use motor oil in your transmission. I recommend either Honda MTF or Redline MTL (not MT90).
[Modified by PatrickGSR94, 11:57 AM 5/6/2002]
Old May 6, 2002 | 09:02 AM
JL 74's Avatar
25 Year Member
Only after 1997? when Honda recommends their MTF fluid after they spent $$$ marketing, labeling, etc their MTF fluid. Before, the owners manual requires 10w30 or 10w40 motor oil.
Old May 6, 2002 | 09:03 AM
denieone's Avatar
thanks for the link vteconly............
i need to buy some stuff for my teg(plugs,cables and some filters).
