Injector plug for ZC swap
Old Apr 4, 2006 | 06:03 PM
Tippyman's Avatar
Default Injector plug for ZC swap
Will an injector plug from a DA integra work on a SOHC ZC engine?
Old Apr 4, 2006 | 06:28 PM
Sikocivic's Avatar
Default Re: Injector plug for ZC swap (Tippyman)
The plugs from any OBD0 Honda should work including 90-93 Integra.
Did you break one or are you useing them for the MPFI swap?
Old Apr 4, 2006 | 06:29 PM
Tippyman's Avatar
I am putting a ZC engine in my DPFI car and i don't know if the engine came with the plugs. So, if it didn't, I need to go get some, and i know of a DA i can get them off of if it will work!
Old Apr 4, 2006 | 07:02 PM
Tippyman's Avatar
Old Apr 4, 2006 | 09:00 PM
crxnj's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">The plugs from any OBD0 Honda should work including 90-93 Integra.
Did you break one or are you useing them for the MPFI swap?</TD></TR></TABLE>
I think you mean 90-91,,,,92-93 is obd1..
Old Apr 4, 2006 | 09:06 PM
silentdork818's Avatar
Default Re: (Mr.speaker)
Im sure Hmotors left them on there...if not 90-91 Integra plugs will work. Theyre grey but they plug in the same.
Old Apr 5, 2006 | 03:14 AM
Tippyman's Avatar
Default Re: (silentdork818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdork818 &raquo;</TD></TR><TR><TD CLASS="quote">Im sure Hmotors left them on there...if not 90-91 Integra plugs will work. Theyre grey but they plug in the same.</TD></TR></TABLE>
Thanks alot!
Old Apr 5, 2006 | 04:47 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
90-91 will definately work. Same plugs and injectors.
If you have a DA parts car, I'd swipe the main relay too.
freitasfamily09
Jun 28, 2010 06:41 AM
90crxdohczc
Mar 28, 2006 07:48 PM
JapJunkie
14
Jan 20, 2005 09:58 PM
idontcare
13
Dec 14, 2003 02:14 PM
ZC_powered_4dr.
Oct 28, 2002 07:36 PM
