Suspension & Brakes Theory, alignment, spring rates....
Ground Control w/Koni "Perch Settings"
Old Apr 4, 2006 | 05:54 PM
jspeed77's Avatar
Default Ground Control w/Koni "Perch Settings"
I've searched the forum for recommendations on which perch setting to use on the koni yellow shocks. I'm installing 400F 450R spring rates. Is the middle perch setting best? This car is a daily driver with auto X during the summer. Also, since I'm not going to use top hats what is the optimum ride height? Not into the slammed look.....handling is the priority! Thanks.
Old Apr 6, 2006 | 10:58 AM
jspeed77's Avatar
Default Re: Ground Control w/Koni "Perch Settings" (jspeed77)
Bump!
Old Apr 6, 2006 | 11:14 AM
CRX Lee's Avatar
The circlip groove perch locations are close enough together on teh konis and the GC sleeve is long enough that which groove you put them on is nearly immaterial. I normally move the cirlip to the lowest groove location when installing a threaded sleeve system and go from there but it won't matter unless the threaded perch is at the very, very bottom of the threaded sleeve.
For best handling and acceptable ride, lowering the car in the 1.75 inch from stock rangewould be a good target. After loaning my '98 Civic coupe to a magazine, I raised it from a 2.25 frop to 1.75 and we were amazed at how much better the car rode and handles immediately.
Old Apr 7, 2006 | 07:31 AM
jspeed77's Avatar
Default Re: Ground Control w/Koni "Perch Settings" (CRX Lee)
Thank you Lee. Greatly appreciated.
John S.
SLOENUF
Suspension & Brakes
Jul 12, 2011 03:52 AM
datssoled
Suspension & Brakes
Aug 17, 2009 01:25 PM
jakeiscool
Suspension & Brakes
12
Mar 23, 2005 02:16 PM
phantom_sol
19
Mar 5, 2004 08:52 AM
cichlid
Mar 23, 2003 09:19 AM
