Help Me Please!!!!! Part 2
Old Apr 4, 2006 | 05:09 PM
Bustinvtec's Avatar
Default Help Me Please!!!!! Part 2
so my b16a is still not running on #2 cylinder and i have tried everything... Recently i have installed Brand new JDM B16 distributor with cap and rotor, new injectors, new injector seals and filters,new fuel filter, new knock sensor, new oil with new filter, new oxyen sensor, new plugs and plug wires. The old distrubutor seized up becuase the bearings inside were dirty and had no oil left in them.. It ran very rough when they siezed up.. almost like it wasn't running on all cylinders... So with the new distributor it starts up and isn't running on #2 cylinder.. I did a compression check and it read 175 in each cylinder. It isn't throwing any codes either!!!!! I do only have the one oxygen sensor in the header and i have the second sensor wire spliced into the current single one.. Please let me know what you think it might be?????? Thanks
Old Apr 4, 2006 | 05:14 PM
ludesrv's Avatar
O2 sensor wont kill the cylinder. Cyl. #2 isnt getting either spark/fuel or the compression is gone. Maybe the timing is off. Take off the valve cover and check out whats going on in there. Stuck on valves can expletive things up a bit.
TravisCadello
14
Feb 6, 2013 07:40 AM
96GS-R-Kaden
May 21, 2008 12:08 PM
pinoy369
13
Apr 4, 2007 07:05 AM
Bustinvtec
Mar 30, 2006 05:35 PM
