compatible trannies for accord/cl 2.2 sohc vtec?
Old Apr 4, 2006 | 02:41 PM
technine's Avatar
Default compatible trannies for accord/cl 2.2 sohc vtec?
My tranny on my 97 CL 2.2 just bit the big one and is now slipping past 35mph and doesn't shift right at all. I forgot the engine code, but I think it's a F22b1 since it's a 2.2 sohc vtec.
Which auto transmissions are compatible with my motor? Could I pull an auto tranny from a 4th gen accord and install it in what is assentially a 5th gen accord? Does it matter if it comes from an LX, DX, OBDI, OBDII? TIA
Old Apr 4, 2006 | 02:53 PM
fw190bvi's Avatar
Default Re: compatible trannies for accord/cl 2.2 sohc vtec? (technine)
theoretically, any tranny from an F22a or b, and f23a, h23a or h22a will bolt up like a glove. i think you want to stay with an OBDII tranny....i know jack **** about AT's, so im not sure how much the difference in the sensors and wiring, etc, between an OBD1 and 2
Old Apr 4, 2006 | 03:49 PM
technine's Avatar
Default Re: compatible trannies for accord/cl 2.2 sohc vtec? (fw190bvi)
Wow, maybe I should convert to stick, lol. I remember when I did a tranny swap on a civic, one tranny that was of the same generation had a different speed sensor than the origanal one, simple fix, but I guess I should just stick with the same OBDII trannies.
Anyone else have the answer? P_Adams?
Old Apr 4, 2006 | 05:05 PM
YeuEmMaiMai's Avatar
all the trannies since like 90 or 91 are electronically controlled and it makes no difference if it has a OBD or OBD2 TCU attached to it as they are pretty much all interchangeable from an electrical connection point of view(from trans to TCU).
Old Apr 5, 2006 | 10:37 AM
technine's Avatar
Default Re: compatible trannies for accord/cl 2.2 sohc vtec? (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">all the trannies since like 90 or 91 are electronically controlled and it makes no difference if it has a OBD or OBD2 TCU attached to it as they are pretty much all interchangeable from an electrical connection point of view(from trans to TCU). </TD></TR></TABLE>
ic, Well, I guess I'm going tranny hunting. Thanks guys.
Old Apr 5, 2006 | 01:38 PM
P_Adams's Avatar
Here's something that may help your hunt.....
1994-1997 Honda Accord DX/LX coupe/sedan manual F22B2 T/Code = P2A5
1st - 3.307 2nd - 1.809 3d - 1.185 4th - 0.903 5th - 0.685 / FD = 4.062 USDM
1994-1997 Honda Accord EX coupe/sedan manual F22B1 T/Code = P2U5
1st - 3.307 2nd - 1.809 3d - 1.185 4th - 0.933 5th - 0.685 / FD = 4.062 USDM
1994-1997 Honda Accord LX/EX wagon manual F22B1/2 T/Code = P2A4
1st - 3.307 2nd - 1.809 3d - 1.185 4th - 0.903 5th - 0.685 / FD = 4.266 USDM
1994-1997 Honda Accord DX/LX/EX sedan automatic F22B1/2 T/Code = MP0A
1st - 2.736 2nd - 1.483 3d - 1.026 4th - 0.674 / FD = 4.133 USDM (Made in Japan)
1994-1997 Honda Accord DX/LX/EX coupe/sedan automatic F22B1/2 Code = A0YA
1994-1997 Honda Accord DX/LX/EX wagon automatic F22B1/2 T/Code = A0YA
1st - 2.736 2nd - 1.483 3d - 1.026 4th - 0.674 / FD = 4.285 USDM
P
Old Apr 6, 2006 | 12:42 PM
technine's Avatar
Default Re: compatible trannies for accord/cl 2.2 sohc vtec? (P_Adams)
Thanks P
racebum
Nov 12, 2009 02:23 PM
endless_sugar
Sep 29, 2009 04:32 AM
Ihatecars
Jul 24, 2006 02:22 PM
BOOSTonHAnD
Jun 2, 2004 08:26 PM
Charlie Moua
Dec 14, 2002 06:57 AM
