1.6L sohc non v-tech engine swap plzzz help
Old Apr 4, 2006 | 01:43 PM
naz2006's Avatar
Default 1.6L sohc non v-tech engine swap plzzz help
i just recently blew the engine in my 91 civic lx and i put in a 1.6L sohc non v-tech jdm engine in and everything externally mounts up except i cant get the 1.5L distributor to time up right plz help
Old Apr 4, 2006 | 01:50 PM
Autoworks's Avatar
Default Re: 1.6L sohc non v-tech engine swap plzzz help (naz2006)
1st. vtec not v-tech
2nd. When you say "time up right" what exactly fo you mean. You need to use the dizzy from the motor
Old Apr 4, 2006 | 01:59 PM
jlicrx's Avatar
since you have LX, it was DPFI - you need to do wiring changes to convert it to MPFI
Old Apr 4, 2006 | 03:36 PM
naz2006's Avatar
Default Re: 1.6L sohc non v-tech engine swap plzzz help (Autoworks)
its a non v tech 1.6 engine and all the 1.5 patrs externally are mounting up right except i cant get the 1.5 distributor to time up right it will crank the car but its spark knocking
Old Apr 4, 2006 | 05:03 PM
Autoworks's Avatar
Default Re: 1.6L sohc non v-tech engine swap plzzz help (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">since you have LX, it was DPFI - you need to do wiring changes to convert it to MPFI</TD></TR></TABLE>
Old Apr 4, 2006 | 05:55 PM
naz2006's Avatar
the 1.5L distributor from the old engine will carnk the car fine its just spark knocking real bad and its not timed up right
That1guyinvegas
Feb 9, 2014 06:42 AM
Bones20
Jan 14, 2008 04:49 PM
Hawks-At-Angels-12
Feb 4, 2006 12:44 PM
Desert_Rex
Jan 5, 2005 03:53 PM
